Removing Remis blinds from Ducato passenger door (2 Viewers)
1881TB
132
51
Hertfordshire
Auto-Trail Comanche, 2013
Spent a few weeks touring Australia and New Zealand about 10 years ago...
Has anyone got any experience/info on how to do remove the Remis blinds from the door of a 2013 Ducato? I have to get them off in order to remove and replace my wing mirror which was swiped by a Portuguese lorry driver.
Cheers
Tim
Nov 9, 2015
366
451
Shenfield, Essex
Carthago Malibu PVC
35+ years mainly in VW's
Tim
I've recently done this on my 2016 Ducato, see here
It's not too difficult, you just have to take it steady
Cheers
Trevor
Jul 13, 2008
3,739
3,880
Low profile
Just 4 screws hold mine in place.
1881TB
1881TB
132
51
Hertfordshire
Thanks, I looked for pre-existing threads but couldn't find one. Got all the info I need now. Don't have the right star headed screwdriver bits or a trim removing tool, trip to Halfords later.
1881TB
1881TB
132
51
Hertfordshire
The replacement mirror doesn't have the cables for the aerial and extra earth. I have fitted it (referring to Trevor's excellent instructions) and all was well. I tested that the mirrors moved and the indicator worked before doing everything up but now the dash is saying that there is a fault with the indicator although they are all working correctly. I will check for a lose connection but it may be a relay or perhaps the system doesn't like the new bulb/wiring.
Bit of a coincidence that it should develop a fault now but perhaps it's unrelated.
Jan 28, 2008
10,117
18,385
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Top fixing on our remix blinds was under the little logo which is easy to flip out with a Stanley knife
You
Fruitfarmer
8
Worcester
Autotrail coachbuilt
Since 2017
I have recently replaced a door mirror and experienced the same problem. It was a pattern part off eBay with an orange bulb. This bulb is the incorrect wattage which causes an error message. I salvaged the original orange lens and used the correct bulb-problem solved.
1881TB
1881TB
132
51
Hertfordshire
Aha, I thought it might be that, I have kept the bulb, I'll swap them over. Ho did you get the lens off to swap the bulb?
Fruitfarmer
8
Worcester
Since 2017
If you move the main mirror anti-clockwise 2 small screws will be exposed. Alternatively you can prise out the mirror which is far more exciting.You may need an orange lens off eBay (£10) if you haven't got the old one.
1881TB
1881TB
132
51
Hertfordshire
The old bulb is larger than the aperture for the bulb in the new assembly so I can't swap them. In any case, the new bulb is coloured orange whereas the old one just had an orange reflector inside the lens. So they are very different. I have contacted EM parts via Ebay and will wait to see what they say. If an original Fiat Ducato indicator lens assembly, including bulb, will fit, I will go down that route.
