The blinds on the drivers and passenger doors are very noisy/rattly when driving. Before I attempt to find a solution has anyone else had this issue and how have you solved it?
Paul
Paul
open them first ...The blinds on the drivers and passenger doors are very noisy/rattly when driving. Before I attempt to find a solution has anyone else had this issue and how have you solved it?
Paul
If it can be done, it will be doneMy other comments was obviously in fun but has anyone noticed daft sticker on the screens that shows that you MUST open them before driving ... would someone really try to drive with them closed?![]()
You can just imagine the risk assessment meeting at Remis blinds when that particular sticker was first discussed!My other comments was obviously in fun but has anyone noticed daft sticker on the screens that shows that you MUST open them before driving ... would someone really try to drive with them closed?![]()
Ours don't rattle at all. They click shut and are held firmly in place.
Ours a bit similar. Have wedged small chunks of foam in where I can, but occasionally fall out over time. So need a slightly more permanent fix.Our passenger side frame rattled against the door glass frame but a bit of black tack held it still.
Ours a bit similar. Have wedged small chunks of foam in where I can, but occasionally fall out over time. So need a slightly more permanent fix.![]()
The way the claim culture is escalating in the UK/EU some clown would do it and then say he was not told they had to open when moving vehicleMy other comments was obviously in fun but has anyone noticed daft sticker on the screens that shows that you MUST open them before driving ... would someone really try to drive with them closed?![]()
... must be intended for the American market then!The way the claim culture is escalating in the UK/EU some clown would do it and then say he was not told they had to open when moving vehicle
I think I'll try an arrangement of dashcam wired to a TV screenMy other comments was obviously in fun but has anyone noticed daft sticker on the screens that shows that you MUST open them before driving ... would someone really try to drive with them closed?![]()
Tomorrow will see if what I have done has improved it.The blinds on the drivers and passenger doors are very noisy/rattly when driving. Before I attempt to find a solution has anyone else had this issue and how have you solved it?
Paul
We had a similar problem on a Hobby Siesta motorhome & solved it with some velcro straps abouy 8" long (sometimes called cable ties) available from a well known internet auction site. You can strap them round the vertical post, easy to remove when you want to use the blinds & only seconds to put back in place.
Let's hope so.We are taking delivery of our new Pilote next week, the blinds pull up from the bottom as opposed to sliding across. This modification is supposed to stop any rattles. Fingers crossed![]()
Yes. I've done that and hopefully sorted out where it was not fixed to door frame. We're setting out soon and hopefully rattle free!I had this problem, there is a small removable piece at the top and there was a screw that was loose on both doors behind it. Tightened them up no more rattles.
Hi Paul, I have a set on my Autotrail. I didn't know they were Remis until I looked them up. Yes, noisy as hell, only had the van a couple of weeks and they're driving me nuts (I have a thing about squeaks and rattles). I took them off the doors, put a rubber edging strip around the entire perimeter, added and self-tapped two extra fixing holes at the rear verticals, and pushed a rubber grommet between the large vertical rail and the door. All this has just about cured it but it was a lot of effort, and fuss. You have to just locate each squeak as you go along, there's no magic bullet. Basically they come with not enough fixing holes with long lengths unsecured which of course rattle. Sloppy design I think.The blinds on the drivers and passenger doors are very noisy/rattly when driving. Before I attempt to find a solution has anyone else had this issue and how have you solved it?
Paul
Now, on to the rest of the van....
