Reasurance ....... (1 Viewer)
Oct 2, 2011
864
571
Since 2011
Just finishing sorting things out for heading odd today. We had not used the fridge on gas since it had been checked at the habitation check so I decided to check all the appliances as we will be wildcamping some of the time we are away. Everything else worked except I couldn't get the fridge to light. Probably not waiting long enough for the gas to get through. I's working fine on 240 and 12v. Didn't have too much time to mess about as I had to head to work. Is impatience the most likely cause?
Hope to see some other Funsters on our way to Poitiers
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Gordon,
Perhaps if the fridge has not been used for gas for some time it may take a little longer for the gas to reach the burner, also check the internal stop valve usually situated somewhere in the kitchen area. It may be when the habitation was done the stop valve was turned off and needs to be turned on again.
Finally your observation may be right it does take a while for the gas to ignite but keep finger on ignition button on fridge until the ignition light goes out.
Have a good trip.
Norman
Aug 27, 2009
19,788
23,077
Hertfordshire
40 years
Could be as simple as a spider or even a mouse nesting in your igniter or chewed through the power cable. Both very unlikely of course but you wouldn't be the first.:Sad:
gordoncbrown
Oct 2, 2011
864
571
Since 2011
Not as unlikely as you might think. We had to get the heater repaired earlier in the year. It was a wasp that was in the combustion area that was preventing ignition. That was a first for us..:Smile:
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
Quite a coincidence Gordon - decided to do the same thing on my Compass last week before heading off to Northumberland - and took me ages to get it lit. Eventually resorted to looking at instructions (!) You need to turn the gas control knob to full on, then hold in, and just keep clicking the igniter until it eventually catches. I have found with such devices in the past that it actually has lit, but wasn't viewing the flame through the little viewing port exactly right - in the case of mine though it was very clearly visible when it did eventually light.
Hope you get it sorted.
Mike
gordoncbrown
Oct 2, 2011
864
571
Since 2011
Yip. Impatience it was. Got it lit at lunchtime there. Almost need to have my head inside the fridge to see the flame. I'll not do that with the oven.:ROFLMAO::Smile::ROFLMAO:
Lindylooj
189
81
Weymouth, Dorset
Autotrail
Newbie from Oct 2011
Ok its me being ignorant but I thought that if you had your gas turned on and turned the fridge to gas that was all you had to do? Where do you find a flame? Durrrrrh enlighten please - by gas if you want! ::bigsmile:
gordoncbrown
Oct 2, 2011
864
571
Since 2011
Inside the fridge at the back lower left side, on the model of fridge I have, there is a small round "window". Once the fridge is lit it has a blue flame in it and is working. Hope this helps
normanandsue
1,871
21,571
van conversion
Must have a look I thought once the igniter stopped clicking fridge was working, it always has up to now. Never knew you could see a little gas flame, must remember to look when I am next in "The Beast"
Norman
GJH
29,450
38,827
None, now sold
2006 to 2022
Norman
It all depends on the fridge model. Our Elddis had one like Gordon's but the Burstner has no little window - you know it's lit if the light by the control is not flashing/clicking.
