Rear steadies when a tow bar has been fitted - AL KO chassis (2 Viewers)
Sep 13, 2019
322
796
Hertfordshire
Bailey 79-4T
Since 2019
Hi Funsters
I have just had a tow bar fitted top on our 2006 Bessacarr E795 MH. To fit the tow bar they had to remove the fitted steadies, my question is there a replacement corner steady available on the market that anyone has fitted? To access the screw thread they would need to come out the side of the MH instead of the back as previously fitted.
TIA
Darren
Dec 2, 2019
4,079
9,097
South Lincolnshire
Rapido 7065+
Broken most bits now
Mine has spring loaded manual steadies in front of the rear wheels - they work very well.
Badknee
7,408
412,851
notloB
Vantage Neo
Living the dream.
Scissor jacks would do it as bjandlin says.
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
ours are set back towards the rear wheels, no tow bar so assume it was to do with the Alko Chassis (spell check turned it into alcohol chassis which would be more appropriate)
DJL220
Sep 13, 2019
322
796
Hertfordshire
Bailey 79-4T
Since 2019
We have a towbar & Alko chassis. I just bought an extra van jack from ebay & use that & the van jack, one either side. £25 / £30 & no instalation cost.
Barrie.
This was my second option if I couldn’t find some proper steadies or bottle jacks. Will purchase a second one before we next go away.
Dec 2, 2019
4,079
9,097
South Lincolnshire
Rapido 7065+
It sure they are strong enough at 450kg a corner? Will do some research.
They don't jack the van up and are only intended to stop the rockin' so don't really take much load. I don't even bother with the metal bar to nip them up, I just let them drop to round level and give them a gentle nudge with my size 12s to snug them in. They seem to be plenty robust enough when I've used them.
DJL220
Sep 13, 2019
322
796
Hertfordshire
Bailey 79-4T
Since 2019
They don't jack the van up and are only intended to stop the rockin' so don't really take much load. I don't even bother with the metal bar to nip them up, I just let them drop to round level and give them a gentle nudge with my size 12s to snug them in. They seem to be plenty robust enough when I've used them.coul you send me the link please
LOL - Yeah I understand they are there for steadies only, my MH is a heavy lump :LOL:
Could you ping me the link as I couldn't find them on the website - ta
Emmit
8,034
17,754
Pilote Explorateur
Jan.2014
I looked at these, it was the overall cost that put me off 😬
Wanted to see if anyone had fitted these too 👍
I bought a pair from a Funster and paid £75 for them.
That's the same price as the ones Tony idle indicated.
I'll get all my money back if and when I change the van.
Jan 22, 2013
1,254
60,366
London SE
A class Adria vision I707
since 1971
I took mine off and sold them, extra weight at the rear and never needed them, but quite happy
To move a little with the wind, if it’s really blowing then turn her to face the wind works for me,
Wannabee
133
130
Halifax
CompassAvantgarde196
30 years on boats now MH now a chugger
I found the common plastic type corner stand steadies (that look like axle stands) didn't work for me, as the gap under the corner of the van was way too high without blocks up to the chassis. And, there was nothing else to fit them under apart from flimsy fibreglass. Until that is, I fitted a towbar and they now fit a treat against a flat section of the bar on each side. A cheap and simple solution to reduce rocking. Does mean some grovelling though to fit them under...
Dec 2, 2019
4,079
9,097
South Lincolnshire
Rapido 7065+
Mine were already on our van when we bought it but I saw them here:
James-Alex
567
1,905
Bath. Somerset
Autotrail excel 640G
Could I use two of these under the tow bar to steady van a bit? Kids running in and out all the time. Would put some wood under them.
Wannabee
133
130
Halifax
Yes, anything that fits the gap and is convenient for you, whilst providing some support will help. The bottle jacks will be quite heavy, whereas the axle stand type are very light. See Corner Steadies
Feb 22, 2020
344
1,007
West Midlands
Bessacarr E582
2011, 11.6m cruiser on Thames for 5 years before
We had a pair fitted by ALKO in Southam. They work very well, easy to wind down, hold our long overhang steady when cranked, and will fold backwards if you drive off if you forget to put them back up - I haven’t yet. I put caravan-style pads on the ground to spread the load a bit, and for soft ground, as the base is only a couple of inches square.
Apr 6, 2019
3,740
7,450
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
My Autocruise with Alko chassis had these fitted at factory - accessed either side from rear and can be operated with suitableextended drill bit - do the job nicely (I added the feet) but do need some blocks to actually reach the ground if tail end is higher than front already.
DJL220
Sep 13, 2019
322
796
Hertfordshire
Bailey 79-4T
Since 2019
They look like the ones I took off 👍
