PVC Side door Fly-screen
Cheshirecat57
Mid Cheshire
None
10 years on and off
As above, anyone had issues with side-door fly-screen on PVC jumping out of it’s guide rails.?
If so have you found a “fix”?
Is it a Dometic one? Has the bottom slider broken?
Its the factory option on my Adria
Nothing “breaks” it just jumps out of the bottom slider
The “fix” is to the separate the bottom plastic clip( rather than force it back in)
Has it been fitted badly?
Hi Cheshirecat57 ours did the same!! Used same method to fix. We think you just have to make sure you”slide” the door holding nearer the bottom so it’s not being pushed out of its tracks. Keep pressure in towards van.
That's exactly what are doing now
At least it’s not just us?
The factory fitted one on our Rapido V68 van sometimes starts to come out of the top rail, as though the mesh is not quite tall enough.
Just keep an eye on it and put it back in place if necessary. Have to be reasonably careful using the screen.
Noticed it as soon as we got the van, but 3 years later still works fine. Perhaps should have queried it under warranty, but too late now; and in any case not too serious.
