- Jul 5, 2013
- 11,727
- 13,706
- A class
- Since 2013
On our latest outing the microswitch on my Hymer basin tap failed for the second time and a few days later so did the one on the kitchen tap. I am getting fed up with this especially as they are very awkward to fix. At the moment I have rigged a simple on off switch using the basin's wiring. So I just switch it on and the pump starts to run and then just open the tap you want to use. The problem is that if you forget to switch it off the pump will probably burn out, so this can only be a temporary fix.
It seems to me that I have three options.
Option 1. Just keep replacing them each time they break. The problem with that is that it will be time consuming for me to do or expensive to employ somebody to do it for me.
Option 2. Do what Lenny HB did and replace the Hymer's submersible pump with with a pressure switched Sureflow pump I have discussed this with him, but my problem is that the noise of that pump running to flush the toilet in the middle of the night would wake up y wife. And also my double floor is only 125mm or so high so it would be very difficult to fit anywhere convenient.
Option 3. Replace the micro switched method of turning on and off the pump with a pressure switch system. This would have the advantage of keeping the quiet submersible pump and also would seem to me to be simpler to do, so . Has anybody done this on a Hymer and if so how did they make it work please. I am not sure how I could make this work with the toilet and also what I do with the existing microswitch wiring. The internal and external shower still work on the microswitch so should I disconnect them too?
Has anybody successfully carried out Option 3, and if so can they explain how please?
Many thanks for any help you can give
