Problem with getting fresh water/ Water pump (3 Viewers)
Bevmezo
5
York
Rv
Hello, please can someone help us with some advice. We have a CI Caricoa, which we have had for a few months. It's our first Motorhome and we are therefore VERY inexperienced.
We are currently in York and we are having some problems with our water situation. It was our first overnight stay last night. We have used the water a few times previously and it worked. We filled the tank up yesterday and when we tried to use the water we only got what was sitting in the pipes and no more. We can hear the pump when it is switched on but we are not sure if it is as noisy as before or a bit quieter? We have tried leaving the bathroom tap open for 5 minutes but still no water. If you think it's an air block could someone please tell us the easiest way to clear it? Or does anyone have any suggestions please. Thanks.
bobandjanie
8,164
15,810
Javea, Spain
Pilote V600g
Hi, make sure the dump valve is shut, if its open you will see water coming out under the van, normally near the boiler.
Close all taps except one, I start with the kitchen open then turn pump until water comes through, then close it and do the same in the bathroom.
Oh and welcome to motorhome fun, if you subscribe, it will be the best £10 you ever spent. Bob.
Apr 12, 2010
4,813
51,826
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
Could be you need a non return valve in line from the water tank. This happened to me once when I renewed a pump. Easy to fit and whale make them for around £ 5
Phil
Jim
Ringleader
Jul 19, 2007
36,431
130,958
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Best guess is the same as Bob's; the water heater frost drain valve. If this is open (most open automatically when it gets cold) you'll get no water pressure. You could just have a stubborn airlock though. Open all the taps, they'll splutter but you should get there in the end. You could try removing the shower head and blowing down the water pipe. Once one tap is running the others start behaving quickly. (y)
Best of luck, if you need more help just shout, meanwhile welcome to the fun. :)
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I presume this is a fixed pump not a whale type? the whales respond well to being plunged up and down in the water.. I presume you can't do that with a fixed pump...
17,635
43,354
if its a fixed diaphragm pump as is common on most vans, the rubber diaphragm itself perishes but you can buy a service kit reasonably cheaply
mjltigger
1,619
2,672
Trowbridge
My van isn't common then woo...
Good luck, hope you get water soon..
Jun 30, 2010
7,924
27,229
1992 VW Auto sleeper Mono
Since 2005 this time
If it's been cold , I think it's something like 6c, and if you have an Automatic Dump Valve then that could be the problem It could be under the seat in the dinette, mines buried among the heater tubes, CHECK under the Van first tho for water running out when the pump is running
43,330
49,484
Turn off all taps.
Open shower tap and set to cold only and remove shower head.
SUCK HARD on the shower hose while the pump is running until you get water....you'll know when the pump starts pumping :rolleyes:
If you get water close the tap and move on to another.
If you get no water refer to above posts re...dump valve etc.
B
Bevmezo
5
York
Rv
Thank you so much!! The tank was empty duh! So looks like this is what had happened. We have put a peg on the system now as we have read that this will stop it from dumping the water again and it was not cold enough for the water to freeze. Just hope that we have not damaged the pump as our's is not sure flow. Well on to the next watering hole to find out. We are living in here for a year now so your advice was invaluable. Thank you again so much. Oh hubby is thinking of getting a spare pump to take along with us as most of the year will be spent in Europe. Do you think it's a good idea? Seems like we have loads of spares for things already.
Scattycat
920
1,262
Mayenne, France
Rapido
We've been involved with MH's for just a few years and after a couple of extended trips we realised we'd be stuffed if 2 items broke down 1) the water pump and 2) gas regulator
So now we carry a spare of each.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Been there,did that on our very first trip :LOL:Makes you feel a right Prairie Hat doesn't it.
Obviously carrying a spare means you can sort problem straight away,but,wherever you are in (most of) Europe you are never very far from a caravan or motorhome dealer who would have something to keep you going.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It is best to buy a pump while you can do it in comfort from home at a good price. Chances are when you are desperate you'll get fleeced too.
I can get a Shurflo for mine at £52 delivered. How many dealers ? especially when you're stranded
TerryL
6,188
8,190
North East
Low Profile
I carry a spare, bought when I thought the original was getting very noisy and on the way out. We tried to get one in Spain but nobody carried the same model, although if it had failed I could have adapted what was available. Survived until we got home.
Oh, and the noise was one of the pipes banging on a bulkhead.......... Bit of rag cured that.
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Glad you got it sorted and thanks for coming back on with the update as not everyone does. Yes the peg trick works but be careful not to leave it on when theres no water heating. If you leave the hot water on it wont dump.
I carry a spare pump too (well i used to when I was married and had a van) hust in case as a few years ago ours went over christmas while we were away. Luckily we stayed on my freidns pub car park in the middle of the lovely norfolk countryside. So we had to go and purchase some water carriers. We managed OK and had a laugh. Just make sure you have the tolls and fittings to change it
No those sureflow pumps are verey well built and are run dry (its only a diaphragm goingh to and fro)
Good luck and happy travels
Phill
movan
21,492
120,753
Moving around
Burstner
since07
Thanks for coming back and letting us know how you went on. These threads are very educational for those of us who may not NOW have the problem but know it could be around the corner.
B
Bevmezo
5
York
Rv
Hi again when I was saying we will get a Shurflo pump as a replacement / spare I did not think about it to much lol. Our current water pump is an Aqua 8 - 1.5 bar - 1.4 amps - 12v open flow 61/min ) none of this means nothing to me being clueless about these things & hubby is just as bad. would such pump be compatible with this Shurflo pump?
I called a Shurflo pump supplier & they asked what the PSI is but I cannot see this on the pump. Also if I go from an Aqua 8 pump to a Shurflo pump do you think we would need any alterations to the pipe work etc. the pump is located under the seats, the boiler is located under the bed.
your help would be grateful - Thanks
B
Bevmezo
5
York
Rv
Thanks for the quick reply. can anyone else clarify if this is correct - do you think we would need alterations to the pipe work etc for a new Shurflo pump
