Hi, I have an Autocruise Stardream 2010 with a solar panel and have got a strange problem with the 12v electrics. When on hook up everything works ok and in daylight hours off hookup everything works. However once we start loosing the sun everything shuts down including control panel and can't be reset. If prior to getting dark I switch the battery to vehicle instead of leisure the electrics work. Both the leisure and vehicle battery were replaced the middle of last year and have been tested and are ok. I have been told that its probably the fuse board at fault and needs replacing. Has anyone had a similar problem and resolved it? I thought its was worth asking before I fork out £ 300 for a replacement fuseboard. Thanks.
