Power options? (1 Viewer)
UberTramp
5
Warrington'ish
63 plate mk7 transit
I've roughed it in a couple of Van's. Time for some comforts. Currently living in my van.
Hello to all.. I might have to explain my situation to give you an idea of why I'm asking this, open to new suggestions too!
So I'm currently living in my van, as a van.. like tin walls n'all that. I'm pretty cushy in there, I seem thrive roughing it!
I have a fair idea of the end goal with the van, but of course funds are the only thing holding me back, and with winter coming I have to be savvy with how I do things.. I'm less worried about heating than I am ventilating the van. So I want a decent fan in there, ideally as the insulation goes in. (I work in construction so this part is going to be cheap and relatively easy for me)
But, with xmas coming and other financial commitments I dont think I can afford the solar to power it until the new year.. so I was wondering, what can I power the fan with?
My first thought was to get a couple of those small sealed lead batterys, those 12v 7ah ones. have one power the fan and the other charging off the altinator somehow? Then just keep swapping them over.
Or is there another option?
Sorry if that was too long! thanks though.
43,367
49,718
A 4" computer fan may be OK but a decent 12v fan will last about an hour or less on a 7ah battery
Charging from the alternator is going nowhere, it could take hours.
The only way that would work is a B2B charger which tricks your alternator into outputting it's full amps..... But that's going to cost more than a decent solar panel and controller which, in winter, is frankly going to be pretty useless anyway.
If you're well away from other people and houses a small generator will be your best bet.
Jul 13, 2008
3,742
3,919
Low profile
Do you need a fan? A couple of roof vents or even just crack the driver and passenger windows will give you fresh air.
Aug 5, 2018
1,567
3,513
a
a few large 120mm computer fans would be cheap as chips and just wire in a resistor to set the speed you want or a four position switch with a different sized resistor on each and have a variable speed :D
Couple of Large lead acid batteries connected to the van battery via a split charger (so you can still start the van in the morning if you do flatten them) they will charge from the alternator without you having to swap anything around.
As for heating get a diesel heater rather than anything propane / butane powered as condensation and killing yourself will be less of an issue.
The diesel heater of choice would be the chinese copy of the eberspacher thingy..
In fact thinking about the fan you could butcher the 12v computer fan into the frame of a "bathroom extractor fan" assembly and sikaflex that into the roof...
As pappajohn says, forget the 7ah battery idea and just get a couple of car batteries from the scrap yard if money is super tight!
Jul 4, 2017
969
2,831
Newton Stewart, UK
Autotrail Imala 615
Since 2000
Silver screens on the cab windows will cut condensation there. If you have glass windows elsewhere, insulation screens on the outside would help there too. Make sure you have window and roof vents open when cooking, even when just boiling the kettle.
Actually, can’t see why you think a fan would help with ventilation. It would only move the air around inside the van, not bring in fresh air or remove damp and stale air.
UberTramp
UberTramp
5
Warrington'ish
Yes I did think of the small desk fan thing, I could use a small battery pack to run it through the night. Can charge them really easy at work. And yes, I'm already cracking the windows!
Maybe I'll just bave to install the fan while putting the inso in and hook the power up later.
43,367
49,718
A 12v desk fan may draw 7 or 8 amps.
A 100amp battery will give you maybe 6 hours use without permenantly damaging the battery......then take up to 24 hours to fully recharge on a mains charger.
There's no easy option to this problem.
UberTramp
UberTramp
5
Warrington'ish
The fan would be extracting air out the van via some ducting over the bed, which is where I'd think most of the moisture in the night would come from. With the windows cracked, I'm sure it would be much better than nothing. Sounds like I'll just have to madmax something together like HandyAndy suggests!
Feb 22, 2011
9,841
20,289
Newcastle under Lyme
Hymer B544 A Class
That van is going to be very cold over the winter and condensation a big problem, not just on the glass.
What insulation are you using, Celotex ? get it in asap followed quickly by that diesel heater.
We don`t want to loose a funster to hyperthermia (y)
Welcome to the forum by the way :welcome4:
43,367
49,718
Only one post left then you need to subscribe to continue or just read the posts for free.
UberTramp
UberTramp
5
Warrington'ish
Wouldn't I need a power source even for a deisel heater?
Feb 22, 2011
9,841
20,289
Hymer B544 A Class
You would, but surely it`d be worth it, especially if your planning to convert it into a proper camper van eventually ?
Your surely going to need basic comforts if your living in the van.
Malcolm Bolt
1,107
2,600
Harrogate
old A class
Yes it would take a fair bit of power when running but the idea is to bring the van temperature up to a comfy level before snuggling down for the night. This would be a relatively short time and so would not drain the battery.
I have to say that is a brill price.
I had a replacement webasto fitted and it was over a grand.
Malcolm Bolt
1,107
2,600
Harrogate
old A class
I reckon you will need to extract air rather than rely on cracked windows. Provide an intake vent low down and some level of extraction at roof top.
Aug 5, 2018
1,567
3,513
a
yes the diesel heater will need power to run the fan that blows the hot air round the van.
I can't see a cheaper way to stay warm than a couple of car batteries and a split charger.
Split charger kit with all wires, cable crimps, conduit, connectors and zipties will set you back about 70 quid for a 140amp capable splitter.
Batteries from scrap man will probably be no more than £20 but they wont last forever as they are not designed to be deep cycled (flattened) but should get you through winter safely and get you going on your project.
And just for reference the reason I promote a diesel warm air blower is that it is dry heat, unlike a gas heater like propane or butane, they give off a lot of moisture when burning and not only that, would most likely kill you from either carbon monoxide poisoning or setting fire to the van while asleep, neither of which is a great long term plan ?
Aug 5, 2018
1,567
3,513
a
If they are totally flat in the morning and he starts the van with a 120 amp alternator... that poor 30amp relay is going to get a fright. ?
43,367
49,718
But it won't be 120amps as the engine battery is fully charged reducing the output considerably.
Why does it take many hours of driving just to top up a leisure battery via split charged.
Misterg
221
213
N Wales
Self build PVC
IMHO: Get a diesel heater (cheap, Chinese if you must), *but* take the heated air inlet from outside the van so that you get a supply of heated, fresh air that pushes the stale, damp air out. It will still be plenty warm enough, even with a 2kW heater, and the heater itself will be happier working harder (granted, you will use a bit more diesel).
Diesel heaters take most power on start-up. I've measured our current Planar heater and it takes 2 Ah to start-up and cool-down, but less than 1Ah to run for an hour. (Our previous Eberspacher was similar.) The moral of the story is that if you need to start it up, you may as well let it run.
If you'll be running the engine often enough to do that^^^ then you can charge a much bigger habitation battery with a split-charge relay.
Misterg
221
213
N Wales
Self build PVC
Diesel or gas both produce water when burned and both have the capability to generate carbon monoxide in the right/wrong circumstances. Indirect heaters (like most diesel heaters, Propex gas heaters, Truma combis, etc. ) separate the combustion air from the heated air, so give "dry" heat inside the van and dump all the nasties outside.
Aug 5, 2018
1,567
3,513
a
Oh I fully realise that.
I took it as a given that the diesel heater would be installed correctly with the exhaust vented to the exterior but what quite a lot of people don't realise is the danger of camp cookers / burners when used without ventilation.
Personally I think the heater would be more efficient if it was sucking the previously heated warm air from the inside of the van instead of introducing cold air (as long as you did have a suitable amount of fresh air inlets) which the standard van, pre being insulated and boarded out would have.
Misterg
221
213
N Wales
Self build PVC
Yes, I'm sure that the heater will use less fuel if it is set up to heat recirculated air, but then the ventilation needs to be dealt with separately (and any cold air introduced will need heating up).
My main point was that installing the heater to draw in outside air kills two birds with one stone - forced ventilation and heating for very little electricity usage (the Planar, and I guess most others, will run in ventilation only mode if heating isn't needed).
We had an Eberspacher D2 installed that way on a boat, and it kept the interior warm, fresh and dry, even in the face of a steady supply of soggy waterproofs, etc. There was plenty of power in the 2kW heater to make the incoming air warm enough. Admittedly, this was only tested to a few degrees below freezing - maybe the best solution is an adjustable flap that can be used to blend fresh and recirculated air...
Aug 5, 2018
1,567
3,513
a
Not it'll be about 50 amps at a guess with decent cables.. Depends on the setup.
I've got 0.2v drop across my 250 amp manual switch and 50mm2 cabling from front to rear on a 250amp mega fuse just after it leaves the Main battery.. Post to post (between front positive vehicle battery and post positive on the switch was nigh on the same, difficult to be any more accurate as I had to walk from one end of the vehicle to the other :D)
I've seen 70 amps on mine (The Land Rover, not the MH)
Aug 5, 2018
1,567
3,513
a
And these are 16mm2 cables
He hasn't said so I wouldn't have a clue... or do you mean the "kit" I suggested as an idea, as they were indeed 16mm2 but 5m long so could probably double them up if he kept the hab battery at the front under the seats.
Anyway, semantics.. 30 amps is a little low for longevity IMO. Yes it would work, but I would always fit something that the switch might in theory see for safety if nothing else. otherwise it's just wasted money when you have to buy it twice because the first one got hot and packed up.
I think Tramp needs to work out a better plan than the one he was thinking though, that's for sure. 7ah "swappable" batteries is way out there in "not the best plan of action". I think we can agree on that. :D
We still don't know what he is thinking of doing for heating, it won't be long before that is needed either judging by the sudden disappearance of the hot thing in the sky.
