- Nov 22, 2018
- 2,048
- 23,053
- Rimor Europeo 87
- Seven years plus three tugging
Was checking the tyre pressures before my last trip and found that they were a tad low. Stuck the 12v socket plug on the dealer supplied tyre pump and nothing happened. Checked the fuse (10a) and it had blown. Replaced the fuse and tried again.
Good grief, it struggled. Wheezing and whining like me on a Monday morning. It barely moved the pressure then just got hot and shut down.
I bought a more powerful twin cylinder pump. 15a fuse and it too has a fag lighter socket plug. However, it also has the option of crocodile clips direct onto battery terminals.
My questions are:
1. On the Ducato base, where are the battery terminals to attach the crocodiles to? It is a bit of a faff to lift the battery box cover (see other post) every time you want to put some air in.
2. Can you use the leisure battery terminals to power the pump?
3. We have an EHU socket on our mains. Is keeping it plugged in while operating a pump a good thing? Or do I need to turn the engine over?
Thanks,
Dave
My questions are:
Thanks,
Dave
