Owl wireless energy monitor (2 Viewers)
Boo
633
4
A cls
9 years
I just got it in the post.........my question is:
The instructions are about installing it in a house, so from what I can gather I need to put the clamp on the main feed into my RV, does that mean I clip it onto the blue EHU cable where you plug it into the RV and install the sender into the locker............or do I find the feed in on the inside of the van?
Where have you fitted yours in your A class? pics would be appresiated :thumb:
Boo
2,337
10,147
Hi Boo
The clamp has to go around only the live or neutral core of the ehu supply, it won't work around the cable .. without knowing how yours is wired it's difficult to advise .. you need to find where the cable terminates and try to find a way to get the clamp on..
hth
Jim
Boo
Boo
633
4
A cls
9 years
Hi Boo
hth
Jim
Well the supply seems to come inside under the cooker.............will the signal get through to the display?
Boo
2,337
10,147
Boo
No problem.. mine is outside in a locker.. about 5mt from the receiver and though a bulkhead.
Boo
Boo
633
4
A cls
9 years
O.K fitted it today quite easily in the waste locker..............it works great! :thumb:
Only thing is, it is in Kw...........any Idea wot I sould set the alarm at?
Boo
2,337
10,147
Boo
Depends on your ehu supply , if it's 16A then you have 3.6kw available, I set the alarm to 3.5kw ..
for future reference, multiply the Volts (230) by the supply Amps gives you the available power in watts ..
V x A = W
so a 10A gives you 2.3 kw
and a 6A gives you 1.38kw
Boo
Boo
633
4
A cls
9 years
V x A = W
It says B16 at the point and 60amp
does it mean it's 16kw
Boo
2,337
10,147
Boo
No
B16 is the Circuit Breaker type and rating = 16A , this is your supply.
The 60Amp is the maximum rating of the main switch ..
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Owl Meter
It a brilliant piece of kit.
Mine is connected round the Incommer Positive after the connection plug, works OK. You can also set it to show the AMPS, Most useful out here in Spain where the sites can be a bit unpredictable. Remember to set the Voltage to the local supply they are allowed to vary it and depending upon local conditions it CAN be from 220 to 240Volts. (eg I have 235V currently at La Manga) but I have seen 210V in other places!!!.
pete
2,337
10,147
pete
Hi Pete
I've never found out how to set to see amps.. :Sad: but not really bothered, once you get used to looking at the kw it doesn't matter..
the alarm and the running kw total are very useful features.. :Smile:
Re Voltage.. that really only matters when monitoring the kw.. it won't influence the amp reading ..
Cheers
Jim
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I heard these devises can make you neurotic about elctricity
I personaly dont belive it
But
Did you know a 60 watt light bulb run for 100 years will cost an average of £645 to run and use 200 tons of coal or 7653 cubic feet of natural gas and produce 3.2 tons of green hose efect polutansts,kill 17.8 trees and the averge user will spend 3.5 years of there life looking at the unit itself
neurotic me!!!! no way
ps dont bother working it all out I made it up :ROFLMAO::ROFLMAO::ROFLMAO:
Geo
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
Jim,
I have sent you two PM's on RVF is the PM side of the forum working okay?
The PMs relate to the Owl Monitor who I wrote to asking if the same device sold in both the USA & UK could be used in either country or was its software fixed to one.
A Dave Cook from the company replied and said this,
The OWL will not be able to get a reading when it is clipped over anything other than a live cable, the electric hookups in campsites (To the best of my knowledge) are multicored cables – meaning that the Live is in the same cable as the earth and neutral.
The only way that you could get the OWL to work in your motor home is if you could safely access the live cable alone, without the Earth and Neutral in the same cable.
Now on reading this I was a little confused especially after watching this You Tube video Installation Video - Owl 113 [ame]http://www.youtube.com/watch?v=knwEPyIrRSI&feature=related[/ame]
I again wrote to Dave saying that in that video the Owls sensor is clearly being clipped over a grey cable, the sort that contains live,neutral and earth.
He replied,
The grey cable in the video is a single live feed, with no other cables in the same insulation. It is quite common for many UK installations to have uniform grey cabling for the meter and fusebox.
I then informed Dave that I would ask you how you connected your Owl sensor and I presume you used the STANDARD sensor and didn't require the large sensor?
Thanks Mick
Boo
Boo
633
4
A cls
9 years
I striped the 3 core casing off with a stanley knife the stretched the live out of the gap (white wire on my USA RV) and clipped the sensor around it..............it's abit floppy but works ::bigsmile:
Boo
2,337
10,147
Hi Boo
hth
Jim
Hi Mick
just replied to your PM on RVF .. no PMs on Fun
See quote.. about where to put the clamp..
Didn't know they did different sized clamps.. anyway , you only need a small clamp, the core of the supply cable is only 2.5sg mm
If you send a pic of where your ehu cable terminates might be able to advise better..
Jim
