Oil level? (1 Viewer)
Apr 11, 2017
1,413
6,814
Earby, Lancashire, UK
Autocruse Select 144
started Oct. 2016
My Boxer 2014 has only 5 of the 6 oil level *'s lit yet the dipstick shows just over the high mark. Is this normal?
Phil
PhilMary
Apr 11, 2017
1,413
6,814
started Oct. 2016
Chaser, do you mean four if the display "stars"? If so, why are there so many?
Feb 16, 2013
19,736
52,043
uttoxeter
ambulance conversion
50 years
Not your engine I know but just an example
joka250
907
1,554
Fylde Coast.
Since 1985
Which is more dangerous too much or too little oil. In my experience there's not much between the 2. Don't rely on dash display use the dipstick, a little below is fine. If at an't time the level rises get it checked out, sooner rather than later.
Reactions: f6c
43,332
49,505
Oil level lights...... Lazy man's dip stick.
Orange oil light.... Tells you your sump bung has fallen out.
Dip stick..... Gives you an accurate indication of oil level... Use it.
Reactions: f6c
Aug 2, 2017
710
671
South Kent Coast.
Yes one light below maximum on the dashboard is about normal. Both the lights on the dashboard and the dipstick just indicates the amount of oil in the sump depending on how level your engine is at the time. It’s not often that you will read about motorhome engines suffering from a lack of oil when driving through deep inclines such as mountains because most engines get their oil from low in the sump. Unless you find your oil level is increasing then you could have a problem with fuel getting into the oil sump due to injector problems etc. Just carry on as normal I’m confident your engine has a a clean bill of health having been a diesel engine engineer for many years.
