2013 van might have been fitted with some 2014FL parts as they started to come down the production line.I'm on a 2013 so X250 and it's the same as TheBig1's picture. The seems to be different variants which is really strange.
Thanks guys, measured the one that came with the obd lock which is a 25mm m6 so ill go for the 40mm as the 30 would only give an extra 5mm which would work but the original bolt in the cab is about 10 to 15mm so should be a good fit.
Already tried that a few times :-(First try, mine was hard to line up. I put all the parts together in the end and the bolt lined up perfectly
Very happy with ours - see here for Funster discount Link RemovedEvening all.
I am considering getting one of the Womo / Camper Protect OBD Port Locks as per the OP.
Just wondering if any of the funsters who have fitted one of these has had any issues since fitting or are they still happy with their purchases ?
Thanks.
Maybe consider adding the extension set to make it as secure as it can be https://www.camperprotect.de/p/erweiterungs-set-fuer-obd-sperreThanks for the feedback - I will get one ordered tomorrow ( and try out the discount code ).
Evening all.
Thanks.
Yes I will also get the padlock option.Maybe consider adding the extension set to make it as secure as it can be https://www.camperprotect.de/p/erweiterungs-set-fuer-obd-sperre
It is listed for that but if you haven't already maybe check that OBD port looks like the one in the photo. If any concerns email a photo of your port to Patrick info@camperprotect.de for confirmation before ordering.Yes I will also get the padlock option.
Hopefully all will be fine with it - I have a 2010 Boxer.
Pin centred Torx are no security, a small screwdriver will break the pin out with no effort at all then a normal Torx bit will fit. Don't ask how I know.it is a security screw, but easily undone with the right bit. It is a torx type screw head with a pin in the centre, so the bit is hollow
How many of you have a Disklok , they're a great visual deterrent ,
I have a Disklok as one of my layers of protection.How many of you have a Disklok , they're a great visual deterrent ,
No Disklok yet but have had Clutch Claw for both car & motorhome for many years as can be adjusted & transferred when changing vehicles but Funster discount code for both on link above. If choosing Disklok don't forget to also buy the steering wheel cover if you have a leather covered steering wheel to prevent damage. Disklok rates very well but like all security is a deterrent that can be overcome by a determined thief with tools.How many of you have a Disklok , they're a great visual deterrent ,
I've just been looking at this device with its fancy cover lugs and an Abus lock - that must cost at least £35Pin centred Torx are no security, a small screwdriver will break the pin out with no effort at all then a normal Torx bit will fit. Don't ask how I know.
It does not fit your layout of fusebox, only the other one with the bolt at the side of the OBD port, not below itOn having a proper look at my fuse box and OBD port I do not believe this device will actually fit. Will email the supplier with a photo to ask their advice.
have you a photo of your OBD port layout?Still can not see one for the fiat ducato 2003. Everywhere i have been looking just sells a dummy port
going to have a good look later it may have to be a home engineered job.
Thanks - I will look for a different product.It does not fit your layout of fusebox, only the other one with the bolt at the side of the OBD port, not below it
