TheBig1
- Nov 27, 2011
- 17,630
- 43,277
- A class
- many many years! since I was a kid
Following on from my increased security for my Ford Transit thread, I decided it would be wise to fit an OBD lock to my motorhome too
Thieves are using technology to steal motorhomes and the tools to do so are cheaply available on ebay. Once in your van, they plug a laptop into the OBD port, an onboard diagnostics port, and using this to disable the immobiliser and start the engine. A simple lock prevent this or at least makes it so difficult that they give up
Beside the drivers knee on the right hand drive model is a cover for the fuse box, which also hosts the OBD port
Undo the 2 screws and remove the cover
The OBD port is bottom left with a dust cover on. Remove the cover and the bolt beside with a 10mm socket
Then assemble the new parts, a plastic cover, a stainless steel plate with a hole, a U shaped steel bracket, a security screw and bit and a padlock
put the plastic part over the port with the hole to the right
Then the steel plate
follow this with the U shaped bracket and use the supplied security screw to attach through the hole and tighten up
Then add the padlock, removing access to the port. The kit comes with a nice quality Abbus stainless steel lock that fits perfectly
Replace the fuse board cover and you are finished
Just 10 minutes to stop your van being stolen, and very easy for anyone with minimal DIY skills
I bought the kit from the link below for just over £50 delivered from Germany and I am very impressed by the quality of the kit
Thanks go to Wombles for arranging a discount
Camper Protect / Womo-tuning https://www.womo-tuning.de/ security devices 5% discount with code MOTORHOMEFUN-UK - see here for more info. www.motorhomefun.co.uk/forum/threads/motorhome-pvc-modding-accessories-discount-codes.184590/page-10#post-4038443
<Broken link removed>
