Motorhome safe
tkk
notts
Frankia i640
newbie but learning fast
Hi,
Ive been given a small safe but not sure what to fix it to in a Moho. It’s an A class on Alde chassis. Where are they usually fitted when dealer/Orem fitted?
Ta
Tk
We have a PVC conversion and I fitted our safe under the rear passenger seats, I drilled and tapped the seat belt framework and bolted and sikaflexed the safe in it is now virtually impossible to remove it.
John.
Thanks,
Two typos in my post “alko” chassis and “OEM” fitted,
Ill look at under seat option
Tk
I never get the hiding a safe issue, if you find a good place don’t bother with the safe
hide your valuables there.
If you buy a good safe then find a location you can secure to and I mean seriously secure at the end of the day the scums will find a safe but it they can’t get it out easily and cannot break into it your valuables will be secure and you can actually access the safe without a load of hassle.
the best place to fit a safe is in the bedroom if you can bolt it from the garage using coach bolts with the nuts inside the safe mines in the bottom of the wardrobe
I got one of the Pacsafe bags I mentioned above. The whole thing has mesh all around of 2.5mm stainless steel cable and the top locks shut and around a fixed object with a padlock (though apparently the padlock that comes with it is prone to becoming stuck locked). I certainly wouldn't put it the same category as a safe, but it is a good discrete anti snatch and grab device.
Just find somewhere to hide it and then just screw it to the floor with wood screws.
