Motorhome Level Mate (3 Viewers)
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Hi Everyone. I am thinking of designing a little spirit level device for levelling your van from the drivers seat without running back and forth to check the spirit level that’s an a flat surface at the back of the van. We all know level surfaces around the drivers seat are ZERO. You will be able to set the optimum position for drains, sinks and showers, lock it’s position and forever after perfect level. If enough people express an interest I can 3D print them and put it in the classifieds.
Paul and Chrissy
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
The idea occurred to me some time ago. But I could not find a way of mounting it, without it either being in the way, or looking like a dog's dinner. If you can crack it, I would be interested.
Keith
Feb 18, 2017
4,130
8,005
Greenwich, London, UK
Hymer MLT 570
I use a free app called "Yescarpa level"
I simply put my iPhone on the table, and it will tell me to within 1 degree if the van is level, and if not which wheels need ramping up.
I have found in my van that if the table is level, then the rest of the van is where it should be regarding drainage etc.
Like most vans, mine is nose heavy, so I always try to park slightly up hill
Jan 26, 2017
3,474
11,742
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
That's ok as long as you can see the table from the drivers seat.
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
Oh! Wassup with the default iPhone one?
How much better is Yescarpa?
Asking as I'd look at improved apps ;)
Edit: screenshots added from default 'measure' app.
As a 3D level
Or as a 2d level
Bluemanc100
445
2,459
Hawarden near Chester
Elddis Majestic 155
MH Novice (but a seasoned veteran driver)
Paul and Chrissy
Yes please
Currently SWMBO sits in the back with a spirit level on the floor which does work well but can’t be done solo (obviously)
18,025
48,095
This can be solved if you use the right app on your phone. :) On Android Bubble level (Spirit Level)
made by PixelProse SARL has a calibration button which is shown as two concentric circles on the screen.
You first park the MH so it is level then place the phone somewhere convenient where it can be seen by the driver.
Then press the calibration button and the bubble will move to the centre as if the phone is level - which it isn't but the MH is. It well remember the calibration for the next time you park.
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
The winding spindle on my skylight leaks in heavy rain when level so I'm happy to be on a slope and without the worry of levelling up to the nearest degree.
So I'm out .... good luck, I'm sure lots will be interested 👍🏻
You will be able to set the van un level if things like leaking roof vents a are a problem. You will be able to pre determine your favourite level/in level position taking into account such things, and then your optimal position will be remembered. No batteries needed. 😊
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Cannot believe no one is using CamperSet app.
You calibrate it to what YOU want to be level. Input wheelbase dimensions and it tells you which wheel needs to raise and by how much, with a great GUI.
With all these apps, do you need to place the phone on a flat surface.
BDM
Aug 17, 2013
155
198
Norwich
Since 2008
So effectively I guess you are suggesting an analogue version of CamperSet, or am I not understanding correctly?
And of course there are plenty that do not want a digital alternative.
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Yes. Old fashioned manual. No electronics.
