Derbyshire wanderer
Only 5"? So 1980's5" outwardly rolled works for me
A motorhome deserves at least a 9" letterbox or a dragster pipe
This is an interesting post for me as I've had discussions with my motorhome mechanic regarding remaps.I've seen two separate x244 2.8jtd Ducatos with weeping fuel rail connections, guess what, both had been remapped! The latest generation common rail fuel systems can deliver up to eight individually timed fuel injection events per cylinder per firing stroke. The fuel system makers and the motor manufacturers spend hundreds of thousands of pounds to create the fueling map. Do we really believe that someone with a laptop can really write a better map? I don't!!
D.
Only 5"? So 1980's
I don't really understand your assertion that diesel engines are "well over engineered". I worked in international automotive and aerospace engineering companies for many many years and that simply is not a concept I ever recall hearing from any Design Engineer.
According to him, my 2009 X250 3l diesel 160hp is capable of easily upping to 190hp and that Fiat caps the hp dependant on country but uses the same parts (fuel pump, clutch etc) for all regardless of what they've set the hp at, so by doing so, would not put any detrimental stress on the other parts, as the design is well within its limits by such a fine tune. (He's offered a full remap personal to my motorhome and has advised that if I'm unsatisfied, that he will return it to its original state).
I'm after slightly better fuel economy. (Tag axle, 5200kgs with massive overcab bed) hence this being an interesting topic to me before I part with my cash.
it might also lead to premature injector problems.
That sums up exactly why I don't believe in remaps.Fiat don't use the same components across a range, my 2009 Ducato 120 bhp has a different turbo to the one fitted on a 130 bhp although the basic engine is the same 2.3 litre unit. What else might be different? Cams, clutch?
How does a third party write a "better" map than the factory when it does up to eight individually timed injection events per cylinder per firing stroke? Obviously the individual timings are not being significantly altered so the only other parameters are boost pressure and fuel pressure. My belief is that many, if not all remaps increase boost pressures and fuel rail pressure ( as an aside modern common rail systems are running around 3000 bar fuel pressure!) Increased rail pressure can lead to leaking joints in the HP fuel system, it might also lead to premature injector problems.
D.
Hi Dave, I should have been more clear with my description in that my mechanic was saying Fiat use the same parts (fuel pump, filter, clutch etc) for the 3l diesel model in the UK where Bhp is 160 as they do in other countries where the same engine has 190 bhp.Fiat don't use the same components across a range, my 2009 Ducato 120 bhp has a different turbo to the one fitted on a 130 bhp although the basic engine is the same 2.3 litre unit. What else might be different? Cams, clutch?
D.
D.
I think u mean 3000 psi
Not 3000 bar !!!!!!!!
I think he does mean 3000 bar which is possible now.
Martin
It sounds scary doesn't it lol43511.32 psi..........seems high as that pressure will cut steel however, upon researching further it seems it is possible in crd, so i stand duly corrected
I guess the point is that we don't know what else the manufacturer does when he alters the power out via the ECU "map"Notwithstanding all the very common sense opinions previously posted - is it not conceivable that when manufacturers offer the optional power upgrade, they are not putting in a different engine or bolting on better parts but simply doing an in-house remap?
From a quickly sourced PracticalMotorhome review:
http://www.practicalmotorhome.com/n...n-motorhomes-for-2017-innovative-layouts-star
"The Fiat’s 2.3-litre engine is available in three states of tune, delivering 130, 150 or 180hp...
and
...Upgrading from the 130hp Ford engine to the 170hp version costs £1200, while on Fiats it is £1200 to go from the 130hp to the 150hp unit, and £2800 to swap the 130hp powerplant for the 180hp variant."
I wonder why one of the "Enthusiast or Modding" publications - or one of the big Remappers haven't done a comparison to see if the £1200 optional upgrade does have any different parts, or whether it simply is a change to the ECU map?I guess the point is that we don't know what else the manufacturer does when he alters the power out via the ECU "map"
...but what if your 130ps engine was actually a 150ps or 170ps that had simply been de-tuned or "underclocked"?I had thought about remapping, trying to weigh up the pros and cons, and had come to the conclusion that being perfectly satisfied with the performance of my Ducato 5+ 130 engine, what was the point in increasing the load on the engine and jeopardising its longevity by effectively "overclocking" it.
Then it would surely have a longer life expectancy thanks to being undertuned?...but what if your 130ps engine was actually a 150ps or 170ps that had simply been de-tuned or "underclocked"?
For the mechanically illiterateWell I know for a fact that Fiat's 2.3 Ducato engine has a different turbo for 120BHP output compared to the 130BHP unit.
D.
