MOT time. Do u empty MH (1 Viewer)
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Mot time in a few weeks, never emptied the Mh, but heard today that as a commercial,van it should be empty.
My local mot man, who only does mot s, and no repairs has never said anything about emptying in the past years on any on my MHs, or company van.
Anybody got views, opinions?
Or actual MOT rules.
43,357
49,636
No need to empty it....it wont fail just because it is too heavy.
It should be a class IV mot....same as a car so isnt a commercial van as far as mot is concerned.
Unless its not correctly registered as a motorcaravan of course.
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Thing is he doesn't say anything, honestly you would think he was deaf and dumb.
Just nods, flicks head left, right, points, then passes u the bill and cert or fail note.
He really is a funny old fella, but reliable if you keep to appointment.
If late he does speak just to say Buxxx off.
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
All motorhomes regardless of weight are Class 4 MOT's, same as cars, all you need is a Class 7 size ramp of the relevant weight capacity and size , and a competent tester!
Wombles
10,810
11,135
SW England
A few years now
We do empty ours but that's for the hab check rather than for servicing/mot & amazing how much stuff we take out! It means an annual cull of what is not used & sorting anything that we need more of.
MikeD
3,936
3,697
London
IH PVC
We get MOT and Hab check both at the same time so yes we do empty everything.
I always think it is a good idea to empty the van once a year to stop the process of continually adding to the bits and bobs/crap that I suspect we all carry around. (y)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
A lot depends on what is loaded and where, its also aimed mainly at cars and small commercials
The requests to unload arise because I may need to examine load area floors and suspension top mounts inside for corrosion and security etc in vans and boots
Some testers insist on empty vehicle, If he misses corrosion or wear as a result of a loaded van its him that gets shot
In a motor home I cant imagine emptying it would give any extra or useful views as its all mainly wood and carpet that I would see not the structure
Geo
Feb 24, 2013
13,094
101,525
Bolsover, Derbyshire
Hymer S800
not long enough
I seem to recall @Geo saying your braking performance readings will be better if you off load the cargo.
As I do the inside bits (see earlier post) I get to see what goes on, the brake tests virtually hit the top of the indicators, the tester said he had never seen anything as high, not sure if have big feet or the Mercedes Sprinter brakes really are that good :)
PP Bear
7,830
28,875
Kent, UK
Auto Trail Dakota SE
Never emptied mine. Always received complimentary remarks on how nice it is etc :)
Mar 2, 2013
348
364
chandlers ford
Astec Devon 2008
July 2012
When finished for the season, yes I empty mine out totally. Open all cupboards, remove bedding and usually take upholstery indoors. Drain down water. Its a good opportunity to check the areas of van that you may never bother with. Goes in for mot in February, same way. Just about to re install everything tomorrow, for Chester, also makes you think about what you really need to take with you.
Jan 27, 2014
2,076
4,565
mid wales
carthago chic i51.
We do the same thing take it all out for winter . mot this week then will load for chester .what we really need.
Apr 13, 2012
5,547
18,784
Mobilvetta Euroyacht
1996, then break 'til 2011
no............ but maybe I should have emptied the cassette .....
17,639
43,424
i rarely present the mot garage with an empty vehicle to test, but do try and ensure it is clean.
Oct 7, 2015
737
3,578
newark
Swift escape 624
An empty vans brakes will lock out sooner and give a lower reading on the meter, All hgv vehicles have to be at max load or they would never meet the test standed as they would lock out too soon,Best is loaded as it will show any possible imbalance to a greater degree.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
For Class 4 vehicles the ATL system will automatically weigh the vehicle and this presented weight will be used for the brake efficiency calculations.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
You are quite right Charlie Inertia is not measured, just braking effort at the wheel.
The % of effort given to any wheel is governed by the brake compensating valve
and the brake compensating valve is controlled by???????
Yes you've guest it Weight
Modern brake rollers also weight the actual vehicle under test, and apply the percentage pass rate that applies to that weight of vehicle
ergo a lighter van will require a lesser braking force % to pass
Geo
