Milenco door lock on Elddis 155 (2 Viewers)
Oct 18, 2021
14
36
Tyneside
Don't own one yet
Hi, does anyone know if there is enough clearance on an Elddis Autoquest 155 to fit one of the Milenco hab door locks that work from inside and out?
Are they worth having?
Cheers
Andy
AndyPK
5,016
13,932
Cirencester
None……..!
Motorhoming since 2015......
Is this the lock you are referring to…..,?:unsure:
Note: not photos of my ‘van!
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
We've got one of the above, definitely worth having for us because it saves having to slam the (warped) door every time, just pull it closed and move the arm partially over it 👍
Jul 25, 2017
408
1,107
Rugby
Elddis Autoquest 185
Since2012
I fitted the same on last two motorhomes,really liked the extra security. Good for making sure grandchildren don’t go walkabout in early hours 😂
We have just changed van and if possible will definitely fit again
AndyPK
5,016
13,932
Cirencester
None……..!
Yep AndyPK that's the one.
The Milenco website gives the necessary clearances for fitting if you’re doing it yourself - I believe that you’ll have enough room for it, and it sounds as if it will be a good thing to fit.(y)
Emmit
8,037
17,758
Pilote Explorateur
Jan.2014
There is another benefit to the Milenco lock (in addition to those mentioned above.
We can park in a car park and retreat to the bedroom. Leaving the curtains and blinds open.
The van looks as if it's merely parked up because the lock gives the appearance of having been
secured from the outside.
PS. Our van only has one door and there are no front doors for either driver or passenger.
