Making the change from lead acid to lithium - a thread with pictures (2 Viewers)
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Just been out to check, charging rate had dropped to 5amps and voltage at 13.7 so I am hopeful they are nearly charged now and giving the EBL a break.
Jun 10, 2010
8,518
20,232
Shrewsbury (sometimes)
N&B Clou Liner MAN
I was worried about that, given even a repair is more than a dedicated charger, do you think it’s worth biting the bullet?
How would I disable the charging on the EBL, is there an easy fuse to pull?
Fan heater, I wanted to see what current it would draw at 1500 watts. More than 100 was the answer.......
watts divided by amps but then you get some loss through the inverter so 1500/12 = 125 amps and then another 10 ish? losses. You would rip through power - both batteries in just over an hour.
Jun 10, 2010
8,518
20,232
N&B Clou Liner MAN
Yes nice and cheap but probably a bit crap like most things from China.
I'm trying to buy less from China, difficult I know but I'm really concerned that the most powerful country on the planet is a totalitarian state.
andy63
4,672
15,017
south shields
since 1990
Phew long read :LOL:....enjoyed your thread.. thank s for taking the time (y)
Like a few on here I've gone over to lithium and on a learning curve..
I still wonder if I'd been prepared to spend an equivalent amount on lead acid whether lithium would have been such a big improvement..in terms of the longevity of the system.. reading seems to suggest it will be worth it and only time will tell..
On your installation do you have any regrets :unsure:( other than your aluminium cable :ROFLMAO: ) on chosing to go through the existing psu with your battery to battery rather than direct to the batteries and possibly then upping the capacity of that unit...
And that is not a criticism as I'm in no position to do so..:ROFLMAO:..
Thanks again...
Andy.
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Thanks again...
Andy.
If I had the room, I would have probably gone for the 60amp Sterling and disabled the split charge relay.
I was just installing one battery so 30 amps was enough. Now I have two, 60 amps would be better but I had already got the 30amp Votronic.
The main issue was space, the Hymer Exsis isn’t a huge van and I only just fit the stuff in I have.
I will see, if we manage comfortably, I will leave as is. Cost was also an issue, it does run away and the bigger B2B was another £100.
My only regret is the money I have spent, but I will forget that soon. :)
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Not through the split charge relay, it’s only a 50amp rated relay and circuit.
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
No it’s actually pretty good, 50amp is a lot and Hymer with no mods will charge a lead acid around 20amps and has decent cabling. UK made vans tend to be much worse.
Sep 4, 2020
165
409
Chester
Hymer S630
Since 2018
Unfortunately I have an older EBL 4 in the Hymer so for my b2b I've got to run a new 10mm cable from the starter battery which thankfully isn't too troublesome as it runs under the MH and pops up right next to the leisure battery. Space isn't great where the battery is stored but following your project I've now got some ideas 👍
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Checked this morning and the batteries were pulling no amps in from the EBL and were fully charged. Surprising as I didn’t think the EBL would achieve a full charge. Ecotree have told me the 14.4v is fine and indeed, does appear to be. Good news for those like me who don’t want to change their normal charger.
Gave the system a good run today with a 1000watt fan heater, checked for hot spots, warm cables and generally any issues.
Absolutely no issues at all and the inverter is quiet and didn't get hot. I can’t see me running loads like these very often but nice to know I can easily if needed.
Checked everywhere for hot cables and points of resistance and happily, only thing that got mildly warm was the cables to inverter which is to be expected.
The only thing left to do now is to see what happens in the real world, I suspect it will be very much improved and for half the weight of batteries.
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
And if you ever did, ie, to use a hair dryer for any length of time, to defrost a pipe for example, you know that by running the engine, you've got the B2B giving you 30A immediately, rather than depleting the batteries first. ;)
Great to see the seat back in and everything looking tidy. (y)
Cheers,
Jock. :)
Dec 17, 2016
960
967
Malvern
Hymer B525 2006 A cl
Cheers,
Jock. :)
I guess if the batteries are allowed to get too cold to charge for any reason ( ie below 2 degrees) you could use the hair dryer to heat them up to a temp where it would be okay to take charge.
Great thread Googlebot , thanks.
Paddy
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Final post as I am quite sure everyone has had enough of being spammed by my tinkering.
Wife working in the motorhome all day and the heating on via gas. Was on a laptop full blast doing teams for 7 hours via the inverter.
Batteries actually went up by 10% which has never happened this time of year! That’s 20ah that has been shoved in on a not all that sunny day while using the heating and the inverter.
I think this will be cancelled out when we are away by the lights and charging electronic devices, but it looks very promising. I used to reckon about 40ah usage a day this time of year so I am well chuffed with that! With careful use, I reckon 6 days is easily achievable. If the clouds and rain are here, 4 days. That’s more than enough for us, with the B2B as well.
Final picture also shows the Bluetooth dongle I got for £20 off eBay which lets me adjust everything on the inverter. Victron kit is awesome, should have gone for it in the first place.
Regarding the lithium, twice the capacity and half the weight makes it worthwhile for me. Whilst there has been a cost to it all, I am confident I won’t need to touch it again for the lifetime of th8 van which I intend to keep at least 10 years.
Thanks again everyone for all your help.
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Here you go, here are the screens available.
I have to say, if it hadn’t been £20, I wouldn’t have bothered. The remote switch on and off via Bluetooth however would be really useful to some, personally, I lean down and flick the switch. :)
53,448
150,056
During a sleepless night (Tam's been talking to me about electrics for his new van :eek: ) I didn't notice an isolator switch inline with your inverter. If you don't have one you really should fit one. On my install I have an isolator switch and a 100 amp relay that is switched remotely.
53,448
150,056
I take it you have the EBL on the Gel setting as I think on AGM it's 14.7v.
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
I don’t have one, do I need one? The inverter switches off and pulls nothing out the battery so I didn’t fit a separate isolator
That’s the one, bizarre and I don’t know if the Ecotree lithium BMS steps up the voltage but they came up as fully charged on it. I probably need to check they were at the correct discharge as afterwards I set the shunt to as I left the solar to do it’s job and then synchronised to 100% once the controllers said they were full.
The temperature sensors also cut in which is good.
3,591
7,778
Amersham
van conversion
Since 2019
The victron inverter it’s got a switch built in, and also via dongle can be switched as well.
If you put another switch, all you do is allow the caps to drain and energise every time you operate that switch. That’s unnecessary stress, caps are the first to reach the limited lifespan then the rest of the board. The built in one, allows the caps to stay energised. I would only fit a switch if there is none built in, and a fuse.
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
It’s fused as are both batteries.
The only place I can think to put a switch is inside the compartment which defeats the object as I don’t think I will open up the compartment to switch it off every time.
I need to move a solar switch somewhere else as well for the same reason, taking the compartment to bits is a pain to just switch off the panels to avoid a full charge when it’s on the drive.
Trout bum
567
584
Ayr
Adria Matrix M670SL
That’s buggered it again!
Just checked the specs of my big panel, it’s a 275 watt and not a 250.
That means it’s too much for the one controller I have if I stick in the 90 watt as well.
As above I am afraid, one is an old 90 watt and the other newer one is a 275 watt.
I reckon I can get a 150 in the place of the 90 watt though, so I might wait till the 90 expires and go that way.
Not easy this motorhome stuff is it? 😂
Check Oxford welding supplies, they have a shop on eBay as well. Definitely cheaper, I got 35mm for 5 a meter and lug.
Always get your cables from a welding supply company much better quality and lots cheaper as well they are used for earth cables for welding plants so they are the best of stuff
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
Went to put the battery cover back on recently and work out where to move the switch to so that I can turn the panel off without taking off the battery cover.
The Ecotree lithium is about 20mm higher than the lead acid and it won’t fit. :-(
Googlebot
Sep 29, 2019
3,058
7,070
Hymer Exsis
20 years
As it happens, I am just chucking out some old drawers where the pattern almost matched.
A couple of hours later and a new cabinet is sorted. I can put the shoes there now where I wouldn’t before as it was just a plastic cover.
Also going to get some magnet catches and make the side piece nearest the camera so it just sticks on and can be removed easily without tools. Means I can leave the switch where it is and also take a look at the solar controller lights if I have to.
Result!
