Ditto that. There’s an app and a website for this. I’ve used it frequently and very successfully in Spain and Greece. Italy is different as they’re very strict about only filling you up if it’s used for propulsion not heating or cooking. We have Gaslow bottles but fill through a port in the skirt of the van, so it looks like it’s going into a tank, not bottles. Even so we couldn’t get gas in Italy.I use myLPG.eu from Google, it's never let me down.
Have you ever done that? Surely it would not workThere' are lots of lpg outlets available in spain, you should not have any issues. Worst case is that you get a bottle of local gas, cheap, and connect it to your fill point.
We use the one in Benidorm, always helpful with adapters and once even sent the boy out to do it for me, although I ended up showing him how to go onRepsol are always my go-to fillup stations.
Clean,
you can either connect it to a barby point or you can buy an adaptor lead that goes from bottle to fill pointHave you ever done that? Surely it would not work
And I should stop calling you Shirley!
Yes this is the hose that connects to the fill point..Have you ever done that? Surely it would not work
Ah I see. So it doesnt transfer to the refillable bottle, it runs through it and stays connected?Yes this is the hose that connects to the fill point..
Gaslow Braided Local Gas Cylinder Connection Hose
The Gaslow Braided Local Cylinder Connection Hose simply screws into the Gaslow filler point and now you can connect any gas cylinder adapter that has a 21.8LH fitting to the Hose. Length 1.5 metres. When using this hose with an external bottle, you are drawing the vapourised contents through...www.gaslowdirect.com
You need a "jumbo" Spanish type bottle connector (no regulator) too, which is further down the page
It just evaporates vapour into the system as you use it at full bottle pressure. If you don't use all the liquid before you have to disconnect, then you've got no gas again. Unless you try and tip the liquid in out of the bottle... But last time I mentioned that it started an argument so I'm not mentioning thatAh I see. So it doesnt transfer to the refillable bottle, it runs through it and stays connected?
Yes it works,you just need a Spanish jumbo adaptor and a hose which you can buy from gasit or gaslow.you need one of your bottles to be empty.just connect the Spanish repsol bottle to your inlet fill point and turn on.the Spanish bottle just sits by your van.a 15 kg repsol bottle costs around 14 euros.Have you ever done that? Surely it would not work
No,please don't do that it can be dangerous.for the cost of the Spanish gas it's really not worth it plus trying to tip liquid gas into your system can gunge it up.That makes sense. Can you send a link to the last time you mentioned that
Even in Italy we found it relatively easy to fill up with lpg especially on the autostradas. Only 1 garage wouldn't fill our tank (even though it's filler is in the skirt not in the locker with the 14kg bottle). We went to the next garage and filled it with no problems at all. We crossed the width of Italy (along the Po Valley to Bari).Ditto that. There’s an app and a website for this. I’ve used it frequently and very successfully in Spain and Greece. Italy is different as they’re very strict about only filling you up if it’s used for propulsion not heating or cooking. We have Gaslow bottles but fill through a port in the skirt of the van, so it looks like it’s going into a tank, not bottles. Even so we couldn’t get gas in Italy.
It can only be as dangerous as filling up at the pumps. The van system is designed to take liquid LPG in.No,please don't do that it can be dangerous.for the cost of the Spanish gas it's really not worth it plus trying to tip liquid gas into your system can gunge it up.
