The2i's
We went to Tiree, one of the Inner Hebridean islands, at Easter. We had booked a space on a croft with no facilities and, knowing we'd have no chance of topping up the LPG on the island, I decided to experiment in advance by running the fridge and occasional heating to see if we were likely to survive a week off grid. All went well and the gas lasted about five days before it ran out. I figured that by turning the gas off to the fridge every night we would just about get by. We wouldn't need gas for cooking as we would be eating with friends at a nearby hotel.
The first minor crisis now! Having burnt every last bit of gas off, I looked on the forum and the first thread to pop up is about an LPG shortage. Marvellous!! Fortunately, I was able to fill up first thing next day but I did spend that evening and night muttering "idiot" to myself.
The ferry was due to depart from Oban at 05:30, earlier than usual and for 'operational reasons', so we found a lovely spot a couple of miles outside town to park up for the night (thanks to @obanvanman ). It was freezing so I tried to put the heater on..... nothing happened. The hob worked so we had a bite to eat, cursed the heater and went to bed. Next morning the van was frozen over and still no heater .
We got to Tiree and, after another freezing night, decided to light the oven to warm the place a little while we got up and dressed. We usually use some cloths to stop the oven rattling so I removed these first.... but, in the half light, I didn't notice the black one at the back. Five minutes later the smoke alarm went off . Strangely, the oven flame was fading until no longer lit and wouldn't re-light.
The hob worked, so we decided to make a cuppa, but watched the flame fade away under the kettle. Soon the hob didn't work either. No problem, I have a mini camping stove with an aerosol type gas canister that would do the job. Or not. It was so cold the butane in the canister wouldn't gas off to light the ring. Five minutes in bed with a freezing aerosol sorted that one out
So, I figured the problem was with the regulator (Truma Mono Control CS) as we had a full tank of gas. The gas taps were all fully on, I checked the crash sensor reset on the regulator, as we had hit a couple of mighty deep potholes on the way to Oban, then eventually removed, whacked and reset the regulator but all to no avail.
After a miserably cold few nights, we did the 'Motorhome walk of shame' and checked in to the hotel for the last few days, absolutely no regrets whatsoever! Bliss.
We stopped off at Keswick CCC site on the way back - I don't think they made much profit as we used every kilowatt of power we could getting the van warmed again .
It seems the Truma regulator is known to block when used with LPG, as mentioned in a few threads on this forum, but our tank has barely been used. I've only filled it three times but thought I may have caused the problem by running the tank completely dry so I've been looking to get a new regulator and the recommended filter to go with it. Time hasn't been on my side and I haven't got it fixed for going away this weekend so I've been out to the van to think about what to do. I thought I'd just try and switch a ring on the cooker on and it worked, everything works!
If you have read this far, any suggestions about why it packed up? The LPG was from the local Shell station, so I assume the quality is ok. Temperatures were around freezing but not much below zero. I'm stumped, but will carry on using everything as usual and hope it's magically fixed forever.
Ahh yes, the two items! The little camping stove and a 2 litre garden spray that we bought to clean the dog. Warm a kettle full of water on the stove, fill the sprayer and you can have a warm(ish) shower with about a litre of water! Perfect to save water if wild camping, or in emergencies when the gas runs out!
Images aren't our exact ones but similar.
