LPG from a bottle to a fitted tank
JohnJan
England
PVC
Since 2011
Is this feasible? If a motorhome was in one place and unable to move and fitted with an onboard LPG tank, could one get a gas cylinder and transfer the contents into the onboard tank assuming the connectors were available?
Best check the Internet, can be dangerous. o_O 👎
Just a question, if you are prepared to lug a full bottle to your van, with a view to transferring it to an underslung, why don't you just use the bottle and connect it to your supply as normal?
Spock would be proud of you. (y)
As i cant think of a logical reason to do what he asks i'll settle for 2nd place:doh:
Feasible Yes if prepared to hold cyl upside down you want liquid not gas exchanging
Practical No
Controllable No
Safe NO
Equipment to do it is available on e bay with free will and funeral plans included
Stand by for the I do it all the time Red Neck invasion :rofl: :rofl: :rofl:
I was just pondering as we have an unused bottle in the garage from a previous van and we're contemplating parking up for a bit and using a car for running about. Logical thought process!! Even if not HSE friendly!!
Regardless of the safety issue, there has to be a simple practicality on physics. Unless you are going to have some sort of pump / compressor, the gas emerging from the portable bottle won't stay in liquid form for longs so the on board tank will have gas as vapour, not liquid form, so it actually won't get very full.
But there are hoses available so you can connect a portable bottle to your fillet inlet and effectively, if your onboard tank has emptied, use the portable bottle as an extended cylinder into your onboard system. http://www.gasit.co.uk/gas-it-reserved-gas-supply-hose-system-pol.html
The standard solution to this problem is to fit a 'barbecue point', ie an external gas outlet. Tee it into the pipe on the the low pressure side of the regulator.
If you hook up a portable bottle with a regulator to the barbecue point (acting as an inlet), the regulated gas will go to all your gas appliances
Have a look at this old can of worms 😂
Ignore the question marks, it's to do with the old forum software not recognising emojis.
Just also make sure that whilst you are doing it, you have left your parrafin stove lit at home nice and close to the net curtains 👍
This is correct, in fact when I had my tank fitted I had a BBQ point fitted inside my old gas locker for this purpose.
If both tanks are at the same temperature nothing will happen because the pressures are equal. If the cylinder is warmer then liquid will transfer propelled by the higher vapour pressure in the bottle (if held upside down). It's a pointless discussion and an unsafe practice if only because no-one would engineer a fully safe connection just for one operation.
