Lost Ducato Oil Filler Cap :( (1 Viewer)
rutteger
61
6
Midlands
Just Looking
Retrieved the motorhome from storage and preparing to leave for a break on 26th. Whilst checking the oil noted the oil filler cap was missing which was not ideal, esp given it is Xmas Eve. Tried everywhere local (inc the local Fiat dealer who was locking up), no luck.
Anyone have any suggestions as to a temporary solution?
Otherwise if anyone knows of any Fiat dealers / motorhome dealers / motor factors who might carry such an item in the Warwickshire / Gloucestershire / Hampshire areas that'd be great.
Cab is a 2012 Ducato 2.3.
What fine timing !
R
rutteger
61
6
Midlands
Just Looking
Would assume I've driven around 20 miles with the cap off. A little oil to the underside of bonnet and engine but not a great deal. Level ok on the dipstick.
Bit of tin plate and self amalgamating tape was the best plan thus far.
TerryL
6,300
8,410
North East
Low Profile
Got any vehicle breakers around? They're bound to have one, especially a commercial vehicle breaker. Try Google.
Although you've probably got no chance until after Christmas now.
Sep 10, 2013
1,190
18,852
Chelmsford Essex
Getting better
Clean and degrease the rocker cover and gaffer/duct/gorilla tape to seal,the idea of an aluminium foil pad over the hole and lightly formed to the hole seems excellent to me. The key to success will be the cleanliness / greasefree of the area the tape needs to bond onto.
Jul 25, 2017
420
1,179
Rugby
Elddis Autoquest 185
Since2012
I'm near rugby not using van over winter. If you need it happy to use mine and I'll sort one when dealers reopen
Ive sent you a PM with my mobile number
Regards
Geoff
734
1,310
cambridgeshire
Bessacar E450
3 years
I once used a round rubber door stop on a sierra gearbox, never bothered to change it and it never fell out
R
rutteger
61
6
Midlands
Just Looking
Will have another look in the engine bay later today, however did have a decent look already.
Geoff - that is a very kind offer. Will PM you directly.
Jul 25, 2017
420
1,179
Rugby
Since2012
Just a thought would not use plastic bag over as engine temp may melt. Whatever used make sure secure as crankcase pressure may blow off. Not sure on diesel what positive pressure they use (emissions ) also if engine a little tired may get blow by when hot
May 29, 2014
2,233
1,884
southampton
A frame
since 1985
a best stay at home until fixed
R
rutteger
61
6
Midlands
Just Looking
Many, many thanks to Geoff for lending me his filler cap.
Would probably suggest not using a poly bag or tape. Whatever is used would need an element of heat, pressure and oil resistance - the cap itself being ideal.
Aug 6, 2013
12,072
16,841
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Not self-amalg - it turns to jelly if exposed to oil.
