just been reading your 'novel' and it does go on a while
looking at the one and only pic in your link it does look in pretty good condition but one or two points to look at.
it sounds like the engine used to be petrol, probably a 2ltr, and a diesel has been fitted.....has the engine change been notified to DVLA ?
has the engine had a new cambelt recently...if its belt driven....could cost around ÂŁ300 to have it changed or another engine if it breaks
you may have problems sourcing some engine and chassis parts depending how old the engine is.
most certainly you wont find many body/conversion parts but most stuff can be substituted for more modern items, lights, taps etc.....original soft furnishing fabric will be a definate no, as will the coach lines which are missing on the front wing (probably both sides).
depending what diesel engine has been grafted in, it should be more economical than the original 2.0 ltr petrol that came out and more powerful.
expect around 25mpg from a 2.5ltr diesel.
as its been redecorated inside it may be hard to see any water staining due to leaks but use your nose.....even oldish damp stinks in cupboards etc.
it may be 4 berth but the rear seats may not have seatbelts so not ideal, or recommended, especially for young kids.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
