12V is thermostatically controlled and (correctly cabled) is as effective as mains and gas.Most inverters can be left switched on, they will as stated consume a small current but ramp up when a draw is made by turning something on. Our Victron 12/2000/80 consumes less than 1 amp when switched on with no load present. When the sun is around our solar (700 watts will run our Dometic three way fridge for most of the day once the batteries are 100 % on 240. Although you are turning 12 into 240 because the 240 is thermostat control it pulls less power the the 12 volt (17 amps) which is constant and not too effective.
spot on..12V is thermostatically controlled and (correctly cabled) is as effective as mains and gas.
According to Dometic the 12 volt will only hold the temp where as the 240 is more powerful. On overnight to Roscoff if we leave the fridge on 12 volt and monitor the fridge temp is stay at a higher temp and uses more power then leaving it on 240 through the inverter even though you are using the same batteries and the inefficient way of producing power. We have medical supplies that must be at a constant temp and had the wiring for the 12 volt side uprated for exactly that reason.12V is thermostatically controlled and (correctly cabled) is as effective as mains and gas.
Looking at the specs for the range of fridges, there is only 5w power difference on 12v than 240v ..According to Dometic the 12 volt will only hold the temp where as the 240 is more powerful.
Upon switching on, the electronics automatically selects one of the three possible energy types: 230V - 12V - liquid gas. The control elec- tronics automatically ensures that the refrigera- tor is supplied with the optimum source of ener- gy in each respective case.If sufficient mains voltage is available (more than 195 V), this power source is selected as prime option. If a solar system capable of powering the refrigerator is installed, the solar 12V supply takes priority.
Sequence of priority:
1.) Solar (12V -)
2.) 230V ~
3.) 12V - driving
4.) Liquid gas
On a more general note, if you have medical supplies that require refrigeration, a compressor model would be more suitable .. they are more reliable, and work at all ambient temperatures...
A 3 way has ambient temperature limitations.. >
Class SN acc. to EN/ISO 7371 in the temperature range of +10°C to +32°C ambient temperature.
Yes - I don't understand why the bigger devices seem to need more on standbyMy Studer AJ275 inverter only uses 0.2 amps on standby
In short yes, those with search mode feature.Hello, Is there an inverter that is able to switch itself on by demand ?
My fridge is 190 watts on 12v and 250 watts on 230v still works quite well on 12v.If I recall correctly, the wattage of the 12 vdc and 240 vac elements are about the same..
The load would be a kettle, coffee machine, microwave all things that are above 40w so that would workIn short yes, those with search mode feature.
Victron up to 1200va inverters consume 2w in search mode (4ah in 24h). It needs a load of >40w to activate it. Larger inverters may need larger load to turn on.
What do you need it for? Whats the load?
ours is similar to yours, perhaps as has been said the modern fridges have larger elements on 12vMy fridge is 190 watts on 12v and 250 watts on 230v still works quite well on 12v.
I find ours is triggered by the display on the microwave, not a problem other than the cooling fan on the inverter can be there at night.The load would be a kettle, coffee machine, microwave all things that are above 40w so that would work
Our 2022 fridge is on a 20amp fuse for the 12v supply, so ours would be similar on 12v I suspect, Perhaps they've made the 230v lessMy fridge is 190 watts on 12v and 250 watts on 230v still works quite well on 12v.
That will work like a charm. In the past, I had a victron 1200va inverter supplying a 950w deep well water pump. The pump was wired to a pressure switch, but, in between the cycles the inverter could sit there for hrs. So I switched it to search mode and worked very well.The load would be a kettle, coffee machine, microwave all things that are above 40w so that would work
And while it's cooling, which was most of our trip, it was using 258 Watts, so ours is the same as Lenny'sOur 2022 fridge is on a 20amp fuse for the 12v supply, so ours would be similar on 12v I suspect, Perhaps they've made the 230v less
That's exactly what I thought. I've recently added a lot of solar, more LFP battery and AC, so I thought I'd put a permanent 12V fridge feed in while I was at it, for when the AC is not required and I have loads of spare electrons.spot on..
odd how that old chestnut keeps popping up.. harking back to the early days when the 12v was only for maintaining the temperature when driving ..
If that's the only problem, it would be quite easy to wire in a 12V temperature controller. This one can switch 20A, which is OK for the 12V heater supply.That's exactly what I thought. I've recently added a lot of solar, more LFP battery and AC, so I thought I'd put a permanent 12V fridge feed in while I was at it, for when the AC is not required and I have loads of spare electrons.
It's a Domestic RM8400 (2019 vintage) and guess what, no thermostat on 12V it turns out. Really annoying! It unsurprisingly gets too cold.
I was just trying to reduce the quiescent inverter load, but I've just had to go back to using it on 230V.
Excellent suggestion autorouter. I shall have a look at that option when I get back from this current trip. Cheers.If that's the only problem, it would be quite easy to wire in a 12V temperature controller. This one can switch 20A, which is OK for the 12V heater supply.
12V Temperature Controller Switch with Probe 20A Thermostat Control | eBay
Relay: 20A. Temperature Range: -55-120â. Long service life. Easy to use.www.ebay.co.uk
