MichaelT
Was thinking of fitting an inverter and have read several posts on here so have a fairly good idea of whats needed. However I have come across an issue that I am not sure what to do about. At the weekend I found the wire for the SP had come out of the crimp so was looking about where I could fit the Inverter and run wiring etc.
We have 2 leisure batteries in the van one under each of the front seats however they do not seem to be connected together in the conventional sense but seem to have wires from each going to the electro block where there is a terminal for B1, B2 and negative. So the question is where would I connect the Inverter to, was thinking just connecting to one battery would drain it quickly as they are only 85AH or would I have to have wires coming from each battery to the Inverter then I would have to have wires coming across the walkway between the seats. Anyone had the same problems, van is a 2016 Knaus Sky TI.
