Evildoody
I have recently fitted a 1.5KW pure sine wave inverter to my motorhome, I thought I would do some maths for s***s and giggles (maybe have a laminated card with the info below fitted to the back of the door for future owners)
(if someone more knowledgeable wants to double check my maths I'd appreciate it) :-
Power Consumption on 1.5KW Inverter (based on 2 x 110AH batteries depleted to 50% = 110AH)
(calculation takes in to consideration inverter inefficiencies)
Microwave - AC 700W/4.79A (actual power requirement AC 1150 Watt) = DC 1150W/106AH
Fridge - AC 220W/0.91A = DC 218.4W/20.09A
Water Boiler - AC 850W/3.54A = DC 849.6W/78.16A
Essentially :-
To deplete 220AH leisure batteries (110AH x 2 @50%) @ continuous runtime=
Microwave = 1hr constant
Fridge = 5.4hr constant
Water Boiler = 1.4hr constant
NB:-
Microwave will run on mains at site or inverter (IF needed) - however usage on inverter of a few mins here and there is negligible
Fridge will run on DC while engine is running, mains at site or gas (Inverter should never be used) - it can but why would you?
Water Boiler will run on mains hookup and/or gas (Gas and inverter is not advised), Gas OR mains is fine and Gas AND mains is fine
Essentially the 1.5KW pure sine wave inverter CAN power all of the above from leisure batteries alone, but is not advised as you can see from current draw outlined above.
NB - 110AH 12V battery = 1.3KW storage
If all above is run solely on leisure batteries, runtime to 50% battery depletion = 30mins max!
Essentially :-
NB:-
