joezanders
- Jun 26, 2021
- 2
- 0
- Bailey autograph
inside the door of my Bailey autograph motorhome it says the rear tyres should be 80 is this true
Can you point to a policy or a case where this has been so? ThanksIf you were ever involved in a serious RTC and your tyres are more than 10% either way, your insurance could be void and even the possibility of be being prosecuted.
Sorry to put a damp squib on things here but be very wary of not abiding by the manufacturer recommended pressures (even though the ride is much better!) If you were ever involved in a serious RTC and your tyres are more than 10% either way, your insurance could be void and even the possibility of be being prosecuted.
That is exactly what it says on the mudguards of our ex ambulance.I use to run by 3.85t van at 65psi rear and 52psi front.
Decent handling and ride comfort with no excessive tyre heat buildup.
There's no real difinative tyre pressure, it's what feels right on the road.
What tyres do you have? If Michelins you will be stuck with a bone shaking ride.inside the door of my Bailey autograph motorhome it says the rear tyres should be 80 is this true
If Continentals take your motorhome loaded with everything you take on your trips and get each axle weighed. Then contact Continental and they will tell you what their recommendation for the pressures front and rear. As for following motorhome converters advice as to tyre pressures, I would always trust the company that makes the tyres. Continental sent me by email a chart for recommended pressures for various axle loads for my tyres, which I printed out and keep in the motorhome.
Edit. 4500kg A class and I run my rears at 5.5bar and the fronts at 3.5 bar, all as recommended by Continental for the axles loads
This in my experience is the case. A lot (not all) of insurance policies expressly reserve the right of the insurer to pursue the insured in the case of negligence or wilful disregard of the law.Insurance can't be invalidated for this reason. There are only a small list of reasons that compulsory insurance can be invalidated for and these largely related to not paying the premium, not have a valid driving licence or not being listed as the driver.
Anything related to the conduct of the driver or roadworthiness of the vehicle is explicitly forbidden from invalidating insurance. This is so that if you are hit by a drunk driving a car with bald tyres you still get a payout.
Policies MAY decided to invalidate the accidental damage portions, or even make you liable to refund the insurance company for 3rd party payouts in such situations. However, they'd have to have specific wording in this regard. Such clauses are frequently limited to drink driving. However, you need to read your specific policy.
Which is only relevant for the American market ;I believe?Just check your maximum rated pressure on the tyre wall before inflating to 80psi
No I believe its for the uk market as well, hence using the word 'tyre' rather than the american 'tire'Which is only relevant for the American market ;I believe?
