Hymer roof ~ stupid question? (1 Viewer)
Jul 4, 2010
1,194
804
Essex / central France
Hymer Star Line 680
9 years
We have a 2005 Starline B680 and I have to work on the roof fitting solar panels.
Is the flat aluminium surface fitted to I guess most of the Hymer models of this era strong enough to take a 75 kg person with soft flat shoes or should I as I have done before make up a couple of boards with soft fabric on the underside?
Flamenca
1,266
804
Europe
Hymer 564
I read somewhere, can't remember where, that the maximum total roof loading on a Hymer is 75kg. I would definitely use boards to spread the load.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I have walked around on mine many times, mostly in trainers / approach shoes for grip. If you are kneeling down, be careful not to put a lot of pressure on a small area or you might cause denting. When I am up there polishing (the only way to get to the top of the front GRP moulding to apply Farecla) I use a large folded candlewick bedspread to work on.
p.s. it is true that the manual states the maximum roof load as 75kg but I think that is referring to carrying luggage if you have roof rails.
43,365
49,701
Yep no problem as long as you are careful.
Tip:
take a mobile phone with you, I once knocked the ladder away and was stranded on the roof for over an hour.:ROFLMAO:
So did i....but it was pi$$img down.
LesleyC
81
153
Surrey
Base bought-no conversion
None at all, but a fair amount of tent camping experience
17,641
43,445
keep well clear of openings like skylights, as its VERY easy to cause a leak
Nov 4, 2011
5,952
39,294
Uk
Very true, after having my Satellite dome fitted one of my roof lights leaked, had to remove it and re seal it,I don't know who or how big the fitters were. So as said stay away from roof lights
