Hymer reading lights. (1 Viewer)
6
63720
Morning all. Recently had one of the 2 reading lights over the beds fail, it's the dimming type with a blue touch button. We don't often use these but it's looks a challenge to replace, has anyone done this themselves please?
Thanks.
Steve and Denise
5,304
14,134
Spalding LINCS
A Class Carthago
Since 2008
We have the same lights one of ours if you turn it on you can’t turn it off, so I disconnected it.
Simple to remove ours has a small screw in one end.
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
I think you have to replace the whole unit.
Try hymer owners group on fb .
Apr 19, 2014
75
83
West Sussex
Since 2014
Is it these ones?
We had three go bad. One or two were replaced under warranty. The whole unit has to be replaced. Our original units used to get hot making me wonder if the higher voltage when on EHU was the cause of the LEDs getting dimmer and eventually failing? I keep a couple of spares now as it would be difficult to replace them with something that didn’t look odd.
Jul 5, 2013
11,736
13,729
All three of ours went at different times. Just got dimmer and dimmer. And yes I know it has a dimming facility but it was not that. Dealer said they are notorious for failing. The bulb is not replaceable so I had to buy new ones
Easy enough to replace. Just unscrew one screw and it dropped down. First one I did I tried to trace the wires back to a junction, which was a right faff. After that I just pulled the wires out as far as I could and then cut them and joined the new ones using wago connectors. There is enough room to push them up through the hole one by one.
If they fail again, I will try to get alternative ones with replaceable bulbs.
63720
Thanks for this. Filled with renewed enthusiasm I found a small inspection cover in the top locker. Having removed this there is just sufficient room to fondle the cables and find the connections down to the fitting. I have now ordered 2 from Amazon and look forward to the battle to replace one. I did think of replacing all these for similar, more basic design, but decided against in case in the future an eagle eyes purchaser spots the difference.
Thanks one and all.
Peppadog
627
824
Nr Bath
Sunlight C600 pvc
Since the late 70's
I think he's mellowed since he bought his hymer, not from travelworld ??
Are you sure? He went ballistic when I asked if others had any doubts about the origin of a Reich pump offer he had created. He turned it into a personal attack on him. I suggested he grow up and then, after a short exchange of views, kicked out. I only knew that when trying to reply with a good by!
Peppadog
627
824
Nr Bath
Sunlight C600 pvc
Since the late 70's
I had them on a 2015 Eriba Triton caravan. One of them used to turn itself off after a couple of minuets. Great they aint. The non dimmable type on my Hymer seem ok though
Jul 29, 2013
9,076
18,637
Salisbury
Hymer B678DL A class
They don’t use a higher voltage when on ECU the still use the leisure batteries.?
Apr 19, 2014
75
83
West Sussex
Since 2014
They do see a higher voltage.
The “bulk charge” phase from our Hymer Electroblok and additional Schaudt chargers when we previously used AGM batteries applied a higher voltage of up to 14.3 volts to the leisure batteries for 16 hours. Any appliance or light in use at the same time also received this higher voltage.
It is not possible for a leisure battery being charged at the higher voltage of 14.3 volts to simultaneously be supplying, say, only 12.5 volts to the leisure circuits.
In the “float” charger phase this drops to 13.8 volts. Off of EHU the battery will vary between 13 and 12 volts.
63720
Thanks.
Job done thank goodness!
It was tight terminating the cables but just room in the compartment in the corner of the overhead locker. We now have 2 extra USB charging ports as well after advise here. Thanks all.
63720
Thanks.
What happened there?
53,648
150,793
I must be living on borrowed time, none have gone in my last Hymer or my current one.
I did have one of the lights around the rooflight flashing. They are the Dometic ones found them on a German site for £20. I just replaced the insert for £4 from eBay, couldn't get a 3 LED one so fitted one with I think 6 LED it doesn't notice.
Apr 19, 2014
75
83
West Sussex
Since 2014
I remember now. Our first warranty failure fell apart. A nut came loose but it didn’t seem possible to disassemble it to repair, The replacement just got dimmer until it failed after a year or so. Then one above the bed did the same outside of the warranty so I had to start buying replacements online. These have been ok for a couple of years now. I recall you don’t use EHU Lenny and i imagine it possible that when you use saloon lights your leisure battery voltage is often in the mid 12v (or less than 13v anyway)? On site with EHU we would often be driving the lights at 14.3v dropping to 13.8v on float and they used to get hot. This lends support to my theory that some of these lights (perhaps earlier versions) failed because they were not tolerant of the higher voltage. I’ve just felt out replacement lights (fully dimmed) and they are cold.
I also had one of the rooflight 3 LED units flashing in the early days and thought I would have to replace it but it’s been ok for a few years after I tinkered with it.
Good the OP got a result and let us know. It makes trying to help more rewarding.
53,648
150,793
Well I learnt something, I never knew my reading lights had dimmers.
Was going to put it down to "real men don't read instructions". Dragged the Hymer book out, no mention of it, just tells you how to turn them on and off.
Apr 19, 2014
75
83
West Sussex
Since 2014
Neither did the service tech at Premier when I first mentioned it! The last dimming level is stored until the habitation power is turned off.
When fully dimmed and used in conjunction with some ambient, v warm-white LED tape and key fob wireless dimmer attached with Velcro near the drivers seat, a very cosy saloon can be yours.
Aug 29, 2010
848
1,262
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
We'll, Lenny HB , neither did I until about a week ago! No mention, either by the dealer when new or in any manual. They do get hot, though.
Jul 29, 2013
9,076
18,637
Salisbury
So come on then tell us how to dim them I didn’t know they were dimmable if you give me the info I’ll give it a go?thanks in advance.?
Steve and Denise
5,304
14,134
Spalding LINCS
A Class Carthago
Since 2008
That makes two of us ? mind you we have only just found the cutlery draw and thanks to you our aerial ?
Buster30
90
32
Derbyshire
Hymer Mercedes ML580
Since 2018
I’ll have to check mine, when travel world did the hab check last year they said one led fitting was not as bright as the other
