Hymer fridge (1 Viewer)
Feb 22, 2011
9,801
20,210
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I have a B544 2003, the fridge is on the back wall and the lower vent is through the floor ! Access is very restricted.
The burner has probably never been cleaned out and it's now refusing to light on gas.
Has anyone found a way to access the burner through the lower vent ? Removing the rear bumper may improve access to the vent but not sure.
Of course if the lotto syndicate come up trump's I'll be trading in so won't need to fix ,!
Aug 6, 2013
11,956
16,571
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I have a 2005 with the same fridge position. There's no way to access anything through the lower vent. Removing the fridge isn't difficult though. Disconnect gas through upper vent, four screws under caps just inside the fridge door, push fridge via upper vent until it moves, then pull it out far enough to disconnect the electrics, then pull fully out into van. The last bit is easier if you remove the fridge door (one screw, upper hinge).
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Agree with @tonyidle above. Had the fridge serviced a couple of times on our 2002 Hymer 544.
The mobile service guy removed the fridge on both occasions. There is an aperture in the back wall behind the bumper where you could access the burner. But, removing the bumper looks more difficult.
By taking the fridge out you can at least give the flue a good clean. If you have difficulty gaining access to the electrics, you could of course unscrew the hob and lift it up sufficiently to gain access. That's what the mobile guy did on one occasion.
Aug 6, 2013
11,956
16,571
Kendal, Cumbria
since 1999
On my B584 the 'dummy' lower inlet behind the bumper is only cut out of the inner skin and insulation leaving the outer skin intact. If I removed the bumper there would therefore be no sign of it.
