- May 10, 2020
- 549
- 1,621
- Carthago
Here you go … a fascinating guide to rear bumper removal. Not the most thrilling read, but hey, it might be useful for someone..
Following a ‘scuff and run’ in Cornwall last year I’ve been meaning to get the bumper repaired. It’s only a scuff with no structural damage to the bumper itself.
I've had a couple of quotes including one for a new bumper and fitting at nearly £3,000 ! - and two different bodyshop quotes of £400 and £500.
I did similar damage to VW Polo a year or so ago and that cost me £120 at the local car bodyshop so, I went back them. They said they’d do it for £120 as long as I took the bumper in to them as the Hymer is too big to get into their unit.
So, I went over to the storage yard this afternoon expecting a reasonable amount of hassle to get the bumper off but it actually only took about 30 minutes.
So if you need to do the same - this is how it goes:
Remove the rear light clusters - two torx screws in each ...
Unclip the rear light units from the wiring harness..
Undo three crosshead screws underneath the van...
Undo two cross-head screws accessed from inside the rear garage in the rear corners...
Undo five torx screws each side of bumper ...
Remove number plate and in recess behind undo two further torx screws ...
Lift bumper up to disengage it from the cross-rail and disconnect any other wiring.
Place bumper in suitable long estate car and take to bodyshop....
Leave your Hymer looking rather naked without rear bumper....
The next thrilling episode of this post will be along in a few days time. This will cover - “how to carefully refit your freshly repainted bumper”.
