how to lock our motorhome from the inside? (2 Viewers)
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
Only parked on our drive but just had our first night in our new portable home ?
We both had a decent sleep but I thought we’d have to abandon when MrsKevenh realised we can’t lock our main habitat door from the inside ?
We’ve a 56 plate Compass Anantgarde 120. Pic of our door handle attached.
Operator error is our hope but happy to hear/read about your solutions ?
Solution
Sorted! ?
Unless I misunderstood some of the feedback, there wasn’t really one fully right reply - it was a combination of several ideas that helped.
So many thanks all contributors??
if you lock & unlock the main habitat door externally from outside, the key slot finished vertical. Finishing either to the left or right. Like l. Or .l
If you take out the key with the slot at the bottom & horizontal (like _ ), then the internal controls are fully enabled.
This allows us to lock the door
bobandjanie
8,166
15,813
Javea, Spain
Pilote V600g
I'm sure we had one like that many years ago, seem to remember you turn it one way to undo, and the other way to lock it. :D Bob.
kevenh
kevenh
3,319
11,801
Thatcham
Compass C-Class
Thanks for the prompt feedback. We’ve a great bunch here ??
You’re describing using the knob central in the pick?
Moving one way - clockwise - does let us out.
Anti-clockwise has a lot of resistance and doesn’t move much ?
I’ll try again after some spinach if that should move more.
edit: and I’ll try the locking mechanism with the door open too ?
19,741
52,057
uttoxeter
ambulance conversion
50 years
The keyhole on the outside has to be in one position though , we had this on our old one, never did discover any other way than one of us had to go outside and lock the door with the key then the person inside had to unlock from inside then the person outside gets in then the door will lock again from inside.
Quite a rigmarole I know but it worked for us.
denisejoe
5,625
12,055
Warden isle of sheppy
Can you lock from outside from the inside it’s anti clockwise as your lock door as it’s on the other side from ours
GPW
606
878
Cambridge UK
Globescout Plus
Slight to minor!
The vehicle bit locks with the 'lock' button on the dashboard next to the hazard switch.
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
Just as a bit more security, we have a strap, similar to a suitcase strap with a clip on it, that goes around the door handle and around the grab rail to get in, if you have one.
3,740
7,451
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
You need to lubricate the top pin of the lock with door open. It has two positions when lock engages. First is like a latch, and second position (doorly completely closed) allows a turn anti clockwise to lock inside.
We thought ours was faulty but then after slamming door it turned.
However, it is strange you can lock with key presumably? Maybe you don't realise you close it with more force from outside than when pulling shut.
kevenh
kevenh
3,319
11,801
Thatcham
Compass C-Class
Sorted! ?
Solution
Aug 11, 2016
353
1,145
ipswich
Not sure
1 year
When you turn the knob anti clockwise to lock, pull the door handle towards you. The door could be slightly bowed and you need to reduce the pressure on the lock.
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Make sure you regularly practice emergency escape plan via front or back . Well worth the small amount of time invested I have a Stanley knife ready to cut strap if in a hurry
