How Do I Convert (2 Viewers)
gypsylady
245
104
Durham
A Happy One
We are looking into investing in a new Generator as our old one is only 800w and is a bit low for what we need.
Some generators have their rating in Kilowatts and some in Kva.
How do we convert Kva into Kilowatts?
Or is it the same equivalent?
Thanks everyone.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
kW is the unit of real power & kVA is the unit of Apparent power. Apparent Power= real power + reactive power
Watts = amps x Volts
Amps = Watts divided by voltage.
a one bar electric fire is approx 1kw.
work it out from there, unfortunately some appliances are marked in Watts and some in amps. you need to know your total use requirement and allow a safety margin. Remember if you up rate your Genny your supply cabling may also need uprating.
2,338
10,133
They are not the same.. it's tempting to think they are but as it's AC power and not DC there is a difference.
1kw = 1.25kva
1kva = 0.8kw
If you are getting a bigger genny, I would look at getting one around 2 kva or 1.6kw
anything bigger will be a) heavy b) noisy
hope that helps
Jim
pudseykeith
382
105
Leeds West Riding of York
6 Years
We have just gone through the same exersize. Having carefully concided the pros and cons we have purchased the Honda eu2 with a gas conversion from Edge Technology. It will provide for all our needs and It runs really smooth. Not cheep but the best never is.
PK
2,338
10,133
PK
I agree, great genny, I have the same one but without the LPG conversion.. worth every penny. :thumb:
43,331
49,480
hope that helps
Jim
not nesseccerily true Jim.
we have a Kippor (yellow) IG 2.6kva and ,yes, it is a bit on the heavy side at 26kg but it is reasonably quite.
can just hear it when its under the rear window and we're watching TV. it does get a little louder if we put a heavier load on it, microwave ect, but not a lot.
2,338
10,133
Fair comment..
maybe I should have said .. anything 'much bigger' rather than just 'bigger'
but by your own admission it is 'fairly' heavy.. notice the use of the word 'fairly' .. :roflmto:
Re noise, they all tend to be 'fairly' noisy on full load .. even the so called 'fairly' quiet ones.. :winky:
Jim
