- Apr 18, 2021
- 215
- 757
- Sunlight Cliff 540
- Since 2008
Just arrived this afternoon on a nice CL in Norfolk, set up, including putting boiler on to HIGH (as I have done many times before.) Water has been heating for approx. 2 hours when I hear a dull 'pop' followed by the sound of running water. Go outside, van has lots of water dripping from n/s sill, near to boiler. The water is warm, so clearly coming from boiler. Lift the bench seat, and behold, the pipe (circled in blue in the photo) has popped off the connection, and water is running INSIDE the bench seat compartment that houses the boiler. Pushed it back on, but loathe to put hot water back on (switched off after event.) At no time did the PRV/drain valve open, so I exercised it open, checked water was draining from underneath the van, then closed it again, including resetting push button.
Before setting off from home, I topped up my water tank, and it overflowed for about 10-15 seconds before I could turn the water off. (I use the modified hozelock connector/cap that allows you to fill it hands free.) I noticed a small dripping from the n/s sill then, but assumed it was just the water from the overflow migrating from the rear o/s and dripping. I stopped twice en-route, and no further dripping was observed.
Any ideas out there? Anybody else experienced similar? I'm tempted to swap the clip on the hose that popped off for a jubilee clip, and just tighten it up, but clearly there is some pressure/overpressure issue going on here.
