Hookup cables (6 Viewers)
Jul 26, 2017
436
925
Elddis Accordo 125
Since 2016
When we got our van it came with a 25m cable. I cut it into a 9 m length and a 16m length. I fitted a plug and a socket to the cut ends. On the 9m one I marked "10 paces" on each connector. One the 16m cable I marked the mid point of the cable and labeled each connector "18 paces". I wound the longer cable doubled onto a cable drum (using the marked mid-point). Why do all this?
Well I now have a short cable that I can use in most situations, a medium cable that is easy to handle, and by connecting them together, one long cable. It's made life easier.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Well I now have a short cable that I can use on most situations, a medium cable that is easy to handle, and by connecting them together, one long cable. It's made life easier.
Did you take into account the verious heights of the bollards and remember to deduct from your paces?;);)(y):D2
Nasher
2,094
7,179
Pontardawe
Pug Boxer
I too made a 15m & 10m cable from my 25m one
Rationale was same as OP - rarely need more than 10m cable, a shorter cable is much easier to coil up & store, especially when wet
g3cwi
Jul 26, 2017
436
925
Elddis Accordo 125
Since 2016
Don't talk to me about bollards. I reversed into one and the van is being repaired today :(
Aug 18, 2014
23,806
133,915
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Place I use in France if you wish to be in a shady spot & using electric then 42 m wasn't enough:( I've another 15m now:sneaky:
mikebeaches
5,396
8,604
Bristol
Rapido V68 Van Conversion
We've stayed at one or two places like that in France, where a 25m + 20m cabled joined, were barely long enough. And indeed at one site we had to borrow an extra length to add to that to reach the hook-up point.
Gellyneck
9,245
18,337
More than toes wet now!
Be careful where and how you you connect the two lengths together as the connection may not meet appropriate water ingress spec.
That's the reason we carry both 10m and 25m cables.
prb
56
50
Aldershot
Low profile coachbuilt
Four years
CMC sites may not like connected cables. We were directed to the site regs when we used two cables connected with 16 amp blue connectors.
g3cwi
Jul 26, 2017
436
925
Elddis Accordo 125
Since 2016
Good point. The connectors are IP44 rated so would probably need some protection in wet conditions. In reality I have only twice had to use both cables here in the UK but I appreciate that things may be different overseas.
Dec 6, 2011
11,600
25,453
South Wales
Coach built Adria
i carry 2 cables,
1 x full 25 meters on a drum ( that gets fully un coiled if used )
1 x 10 meter cable for those close by hook ups and use in my drive.
also carry one of these...
Dec 6, 2011
11,600
25,453
South Wales
Coach built Adria
it fits better and safer than a Tesco bag!!!(y)
Gellyneck
9,245
18,337
use this and you could save the Tesco bag for "MORE "! beer....
Yur jist too smart fur this place!:rolleyes:
An yill save 5p an awl oan havin tae buy anither bag!:eek:
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
IP44 rating means they are OK out in the rain, from any angle. Just make sure they aren't in a puddle, because they're not rated for immersion in water. At Anglesea Abbey near Cambridge there are dozens of these IP44 plug/sockets laid on the grass for the winter illuminations (The flashes are the illuminations, not sparks from the wet connectors:eek:)
You can get IP67 rated plugs (proof against temporary immersion), which have a kind of screw collar and sealing ring. I bought one then discovered it won't fit my MH Mains inlet - the collar gets in the way:(
Robmac
193
2,523
Wyboston, Bedfordshire
Renault Master self build
On second van now since 2012
I use a short and a long cable. 1 x 10 meters and 1 x 15 meters.
This is fine for most situations. The only time I have ever had to connect the 2 were at a meet at a pub where the power supply was in a barn.
I also have 3 of these;
Amazon product ASIN B00CHITOTG
2 for the EHU cables and one for a long ariel extension lead to plug into a site ariel point.
May 29, 2013
2,603
19,279
Tyneside
Chausson best of Flash 10
Several years now
OR, you could have a very short lead and a big generator. Sorted, your welcome !!!
11,956
16,570
OMG yet another CC Ltd rule :madder:.
But a sensible one. If there's any chance a puddle could form under the connectors during a rainy period the exposed connector is not rated for partial or total submersion. If everyone could be trusted to ensure that couldn't happen then there would be no need for the rule - which is the case with most rules.
