Hook up charging question lol (1 Viewer)
Dazz
300
316
South Wales Valleys
Ford Chaussonflash02
As This is my first MH I’m on here a lot lol anyway I have a ford Chausson Flash 02 2008 58 plate today I plugged the hook up in off house supply and took a photo of the control panel before I hooked up so my query is does anybody know while I’m hooked up will my vehicle start battery also charge as well as lesuire battery
Dazz
Dazz
300
316
South Wales Valleys
On control panel I can see twin battery symbol but I’m not sure
18,035
48,140
Leave it on charge overnight and then check. The displays suggest both cab and leisure batteries are at the same state of charge but on its own this doesn't mean both are now being charged.
If both show an increase in charge over time you will have you answer.
If you have solar you could repeat the experiment - if you see some sun of course. :)
43,334
49,533
I can't see the point in it showing the state of charge in the engine battery (pic 1) if it isn't also charging it.
Pic 2 is hab battery.
Dazz
Dazz
300
316
South Wales Valleys
I found manual book today in all paperwork I have I firstly checked the control panel after being plugged into mains for 24 hours and leisure battery has gone up one green dot but engine start battery still same so only thing it says in book is these batteries are fitted with a joined relay between them and when engine runs both batteries charge and once engine is turned off you then use leisure battery it won’t drain engine battery so if I’m write this means that the engine battery won’t charge up from the 240v mains only when engine runs if this is case is it worth fitting a trickle charge to the start battery to keep it topped up if not in use ?
Feb 22, 2016
3,620
10,748
York
Bailey 620 Approach
If I've understood you, your engine battery won't charge when on hook up or on solar. That is almost the same as our Bailey. On hookup, it will only charge up the leisure battery. On solar, it will charge both leisure and engine.
So we had a Battery master fitted. Now, when we are on hookup, or using solar, the engine battery is charged as well as the leisure battery. Can buy the Battery Master from the site. There are similar devices available, some that work on different principles but achieve the same thing.
Good luck.
May 31, 2015
11,686
44,545
Ducato PVC
Getting Better
The engine battery might only start to receive a trickle charge once the hab batteries are fully charged...?
Dazz
Dazz
300
316
South Wales Valleys
Yeah ill
Leave it plugged in at moment then check it later this evening
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Normally, the cab battery will receive a trickle charge all the time. If you have a multimeter, or can borrow one, you could check the cab battery. Check it with the hook up turned off then turn it on and see if the voltage goes up.
Dazz
Dazz
300
316
South Wales Valleys
As ingwe said I could get a battery master fitted but I’m wondering if it’s worth just fitting a foldable dash solar panel on dash board and connect it to start battery just to trickle charge it to keep it topped up I’m off up Nec show Sunday so prob look for something
Feb 22, 2016
3,620
10,748
York
Bailey 620 Approach
I’ve seen this done, but the beauty of the Battery Master is it’s fit and forget. Easily fitted and that’s it.
May 29, 2013
2,603
19,274
Tyneside
Chausson best of Flash 10
Several years now
We have a 2014 Chausson on a Ford base with a pretty similar display to yours. and can state that when on hook up the Leisure AND Cab batteries do get charged. But ONLY if you switch on the top right hand power switch on your panel, as in your first pic. This effective allows the cab battery to charge.
Also, if you are driving with the fridge switched to battery ie keeping stuff cool when on the move, probably like ours you need the same switch on to allow the fridge to operate.
Dazz
Dazz
300
316
South Wales Valleys
Hi sandancers my fridge works when I’m driving without that control panel right hand switch on all I do it turn fridge switch to battery and that works
Dazz
Dazz
300
316
South Wales Valleys
Il try that right hand panel power switch later to see if the double battery light lights up
