HeoS water connector (1 Viewer)
Nov 4, 2011
5,943
39,030
Uk
Since I got my HeoS water connector it always leaks a lot of water, I thought I may have the wrong washer setup (vented or non vented) but then I thought about how the pipe comes of the back and how the fill tube runs.
So I thought I would try a extension tube on the connector, tried it today and no more leaking, I think the water was hits the back of pipe and bouncing back out.
Jan 13, 2014
3,609
11,591
Leeds - Yorkshire
Thanks for the tip,I had an argument with mine again this morning whilst filling and it won l ripped the bloody thing off and stuck the pipe in,will try it at next fill
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Thanks for this, I’m going to try it too as I’ve experienced the same with water coming back out in gulps - and mines fitted with a breather pipe inside the filler.
18,033
48,138
The problem I've experienced with ours is when using a lay flat hose with a low water pressure the hose kinks and stops the flow. This happens because of the weight of the hose is pulling vertically down but it has to enter the Heos connector horizontally. You can overcome this by lifting the hose manually but this makes it a two person job if the tap is one of those you have to keep pressing the button to maintain the flow. So with a few Hozelock connectors and a short bit of garden hose I made up this, which works a treat. No more kinky hoses. :)
Mar 23, 2018
416
606
East Devon
Since 1995 + 20Yrs a 'Tugger' first.
LOL! thought I was looking at mine! I have done exactly the same and it's a good improvement.
Jules132
64
24
Chessington, Surrey
Elddis Autoquest 196
Since August 2017
I find that the hose stays in my van by itself when using the pointy spout adaptor when filling up fresh water :)
Manic
Nov 4, 2011
5,943
39,030
Uk
Jusgg tv this 90’ elbow (£2.65) to help take the pressure of the spigot and it stops the hose pipe flattening when these not much pressure.
Feb 9, 2008
4,094
5,913
SW Scotland
LP Coachbuilt
I use a watering can.
Manic
Nov 4, 2011
5,943
39,030
Uk
I bought it from a farm shop come pets and garden type place near Biggleswade.
Oct 25, 2019
42
63
Letchworth Garden City, Hertfordshire
A/S Warwick XL
Motorhomer since 2019. Previously 10+ years caravanner.
I
I'm interested in using something like this on my Benimar Mileo 264...
... trouble is that my 264 has a water inlet hole internal diameter 45mm. This item and others that I have found seems to be for 67mm diameter.
Has anyone found such as this to fit a 45mm diameter hole pls? Non vented tank.
Regards, F
Gellyneck
9,241
18,307
More than toes wet now!
I
I'm interested in using something like this on my Benimar Mileo 264...View attachment 353228
Regards, F
Have a look at this one. Says it fits a Benimar.
