Help Required With Tap Fitting. (2 Viewers)
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Just spent a lovely few days up at Fort William and climbing Ben Nevis with my daughter Sophie, yesterday when we got back to the van and sitting having a cuppa I heard the pump come on for about a second for no reason. I immediately turned it off and had a quick look around and found my kitchen drawer had a couple of drips of water in it so after further investigation I found the tap tail leaking so when I go home this afternoon went round the 3 shops in Dumfries and 2 told me I need a new tap other didn't have anything to fit. I doubt I need a new tap, so can any of you tell me where I can get similar to first pic below and if the second pic would do the job. First pic shows both broken one and what it should look like.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Thanks Sally it's not the blue part I need it's the white end and tail that fits into the blue push fit fitting
Apr 29, 2014
462
253
Warwickshire, UK
Chieftain
Ok try caravan spares from Kineton near Banbury you can order on phone next day delivery if you can't find them I have there num somewhere let me know
andy63
4,672
15,018
south shields
since 1990
Had a similar experience where the plastic tail into the tap broke and tried to source replacements. ..
Ended up getting a new tap and made sure I bought some spare tails that fitted it...just in case it happened again...
I've kept the original tap just in case one day I come across tails that fit.....I did go back to the original supplier who tried to help but all the leads drew a blank...
Hope you get sorted...
Ta Andy.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Thanks for the replies, I'm not to bothered about the tails if I could get the wee white bit I could make up something with some flexi pipe.
andy63
4,672
15,018
south shields
since 1990
It's the little bits that fit the tap that I ment. ie these.
Photo below in separate post ...sorry
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Hi Sally tried googling them and can't seem to find them so if you don't mind I could do with their number.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Ta Andy.
I've looked at the taps bit they don't come with the tails so surely they must sell sepreately
andy63
4,672
15,018
south shields
since 1990
The bottom one for the new tap I had to get because I couldn't source the top one... It was 8mm with a different sealing arrangement. ..
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
The bottom one looks like it Andy of i could get one of them and a bit of flexi pipe I could make something up I'm sure.
Feb 9, 2008
4,094
5,914
SW Scotland
LP Coachbuilt
I've used araldite in the past on a leaky shower tail.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Ok... I've got 4... pm me your add. I'll send you two and hope it sorts you out... The bottom one is a 10mm tube with the o ring.
Cheers Andy, I might take you up on your offer firstly I'm going to go back to the dealer and see if I can get some bits and bobs to make something up if not I'll be in touch.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
I managed to get a hold of the tail in the last pic (red one) and it seems to have done the job time will tell.
Thanks again for your help and suggestions even Chris :)
17,635
43,358
I had the same problem a few years back with a swift van. Tried all the usual suppliers but couldn't source the connector. Even swift couldn't help or wouldn't whichever. So I changed the tap
Problem is certain manufacturers source parts based on unit cost rather than quality and reliability
