Help please .. stalling engine (1 Viewer)
movan
21,492
120,753
Moving around
Burstner
since07
This re my daughter's van ... it keeps stalling in dangerous places ... traffic light, crossroads and roundabouts. In order to get it going again she has to really rev it to a ridiculous level and it isn"t the way she drives .. it happens with others. It is almost as though the fuel suddenly has a blip ... recently she had a new hose so it can't be that. Any suggestions please.. Thank you.
Feb 24, 2013
13,094
101,527
Bolsover, Derbyshire
Hymer S800
not long enough
Hello Joy, I know it will cost, but has it been serviced recently? It could just be something simple that would be picked up at service, if it has just been serviced take it back (y)
May 31, 2015
11,712
44,634
Ducato PVC
Getting Better
It will be fuel or electrics and my bet is fuel....
What make and vehicle is it ....?
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Joy it sounds as if it is being starved of something either air or fuel........check that ha air filter is clean first of all........if clear could be dirty fuel.......in your case you may need to get someone to have it given a once over.
andy63
4,672
15,018
south shields
since 1990
Hi joy.. I know I saw the van at terry's but can't remember much about it other than it looked good when Terry finished it.... put a few details up on what it is ie make year diesel/petrol etc and ill bet someone will have an idea
Hope all is well...
Andym
43,357
49,636
Blocked air filter.....it would do it all the time and belch out black smoke when it did run.
Blocked fuel filter.....it wouldn't rev properly at all.
Electrical fault....Maybe a faulty fuel cut off solenoid or similar but could also be an intermittant faulty crank or cam position sensor.
Faulty fuel pump.
Clutching at straws as its impossible to diagnose without being there.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thanks John... will take copy of those suggestions .. it is really a matter of not being fleeced by a garage. With those we sound like we know what we are talking about.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you everyone will look at all your answers and deal each one in turn. Your help is very much appreciated.
43,357
49,636
Don't know how old it is Joy.
You say it had a new fuel pipe fitted.
If it's got a mechanical injector pump, rather than a high pressure electric pump, it may be drawing air in between the tank and lift pump or tank and injector pump if its a combined pump......possibly at the fuel filter if not the new pipe.
At higher revs it may not be as noticeable as more fuel is being pulled through the system.
If it's a JTD engine this won't apply but if its a TDiD it could apply.
17,639
43,425
if the old fuel pipe was replaced because it was perished it may well have caused the fuel filter to partly block up
Dec 12, 2010
5,422
21,647
Cumbria
If it's an older type of van, check if it has a rubber priming bulb or pushbutton near the filter, these sometimes perish and draw in air at low revs, stalling the engine (y)
movan
movan
21,492
120,753
Moving around
Burstner
since07
Computer dumbo here. Please can someone tell me how to copy this entire page so I can paste it to my daughter on an e mail. Thank you.
Sep 3, 2012
7,560
26,091
Cheshire
C Class Elddis 175
8+ years
Hi Joy
if you hold down the left mouse button and scroll over/highlight what you want to copy you can then paste it into word or on an e mail. You may need to delete all the unwanted bits -avatars etc
tonka
10,838
21,550
Cannock, Staffs
A class Burstner 800
Since 2000
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you everyone. Have tried your suggestions. Will let you know what the problem is once known. Help much appreciated.
17,639
43,425
click on the page then on keyboard press and hold the CTRL key then briefly the a key then the c key
open a new email and click in the message area, press and hold CTRL again then briefly the v key
copies and pastes the entire page
17,639
43,425
oops just thought if not a laptop and using a tablet, you need to select all the text on the page, copy to clipboard and paste into email. varies in method between an ipad and an android
Jun 17, 2012
2,935
9,955
North Essex
Autotrail Delaware
>12 but <13
Joy, it would help if you told us the vehicle, petrol or diesel, make model etc.
movan
movan
21,492
120,753
Moving around
Burstner
since07
@Larby sorry its a Mercedes base ... deisel. Very old and green... sorry I am rubbish ..oh I think it is a Spritzer or it sounds something like that. . It has done 100,000 miles so not new.
Jun 17, 2012
2,935
9,955
North Essex
Autotrail Delaware
>12 but <13
Do you know anyone that could do a code read depending on age? Unusual for a diesel to stall at low revs. Some of the vacuum pipes may be old and cracked, there are lots of them.............
17,639
43,425
movan
movan
21,492
120,753
Moving around
Burstner
since07
