Help needed with Cruise Control (1 Viewer)
Emmit
8,035
17,755
Pilote Explorateur
Jan.2014
Greetings All,
Got our 'new'? van back to Cornwall in all the wind and rain but there is an issue.
I tried throughout the whole journey to get the Cruise Control to work without success.
We have CC in our car but this one is minimalistic to say the least when it comes to assistance on the stalk.
I'm going to try to describe it and if I'm lucky I'll post pictures!
Here goes; The stalk is on the left side of the steering column. It can be pushed up or down, towards me and away from me and it returns automatically to it's original position.
On the end of the stalk is a microswitch marked "I & II" In the middle of the stalk facing the driver is a triangle (pointing up), with a 'plus' sign inside it. In the middle of the stalk at the bottom is a triangle (pointing downwards) with a 'minus' sign inside it.
Additionally, on the top edge of the stalk, is a triangle pointing away from the driver. This triangle has what appears to be an "l" inside it and on the corresponding bottom edge of the stalk is a triangle pointing towards the driver with a "C" inside it.
For some reason I am unable to load the pictures sorry, but all assistance gratefully accepted.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Sounds like a CM35 stalk ...
Dave Newell (Funster) fits these so why not send him a PM and ask how it works.
Aug 27, 2009
19,788
23,077
Hertfordshire
40 years
Greetings All,
Do you not have a manual, normally there is a separate switch that selects or deselects CC, When selected you should have a light on the dash indicating on. It is at this point that the stalk control will operate. Good luck.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Greetings All,
Push away to turn on(centre symbol should then light up, if not that explains why its not working)
Pull to disengage.
Up to set or increase speed
Down to resume or decrease speed
1 & 11 on the end are for pre-set speeds, press to go to that speed,press & hold for a beep
to set a new speed.
Emmit
Emmit
8,035
17,755
Pilote Explorateur
Jan.2014
Greetings Again,
I just knew I could count on the Funsters.
JeanLuc, you were spot on. In fact, looking at the various images, one of them was from Bridgewater Electronics and, knowing the history of the 'van, It's possible the unit came from there.
I've been out to the 'van as suggested by Jay and the centre button does indeed light up when the engine's running and the unit is put 'On'.
I'm no technophobe but trying to get a CC on when driving into a gale in the rain on the M5 is not recommended. I've printed out the operations for the next time I'm out. No doubt it will come as second nature in time.
Thank you all once again.
golly
2,006
69,658
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Pull to disengage.
to set a new speed.
I had same setup on previous van. the above instructions are spot on.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
If it's any help I can email you the operating instructions (includes pictures)
Send me PM with email address.
To do this click on the username: WynandJean
Wyn
43,344
49,545
speed control adjustment for the aforementioned cruise control
simply place a diifferent sized marble under rhe pedal to set the speed :thumb::roflmto:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Pull to disengage.
to set a new speed.
Jay has it "Bang On" I would simply add
Push away to turn on / Push away to turn off
Pull towards you to disengage / or to re-engage at the last set speed
Up to set speed or to increase by 1mph
Down to Set speed or reduce each time by 1mph
:thumb:
Mar 26, 2009
8,165
11,231
Yr Wyddgrug
Hymer B678DL
I thought it was a 1/2 mile adjustment per movement of the stalk. But I'm only 1/2 sure::bigsmile:
43,344
49,545
I think most CC have this nudge feature, even if its not documented and I believe its 1km/h so about half an mph.
both my car and RV have the 'nudge' feature and definately 1mph increments....unless the stalk is held then its acceleration until the stalk is released.
The RV has steering wheel mounted buttons but add up to the same thing.
Probably on european l/h/d vehicles it could be 1kph increments as the speedo would originally be in kph
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Ours is 1MPH or hold the nudge for a second (up or down) for 10MPH.
Mar 26, 2009
8,165
11,231
Yr Wyddgrug
Hymer B678DL
From my documentation:
3. KM+ (accelerate). When the Fix/KM+ button is held in when the cruise control system is active the vehicle will accelerate until the button is released. The vehicles speed will be maintained at this new increased setting. This button also provides a "tap up" feature whereby each short press of the button will increase the vehicle's speed by aproximately 1/2 mile per hour. 10 clicks in quick succession will raise the speed by about 5MPH.
Thank heaven, I was beginning to think I'd imagined it.:Doh:
