General building advice (1 Viewer)
Aug 22, 2017
829
1,946
Wildax Europa PVC
Since 2014 -- cycle-camper before that
I think the intention was to lay artificial turf over the top, with the concrete just acting as the base to take the weight. Which is why I thought a concrete solution was a bit of a sledgehammer to crack a nut. Just remove 40 to 50mm depth of soil and put down plastic grids, lay the artificial turf over the top -- job's a good 'un. The plastic grids can support many tonnes per square metre -- if you are paranoid, you can fill them with pea shingle and they'll support even more.
309496
309497
309498
dixieland
88
55
Herefordshire/Eauze
since 2011
There’s so much rubble in the ground that I think the builders used it as a rubble dump and then put 6” of topsoil on for the grass..!
Was just going dig two trenches and get a couple of dumpy bags of concrete a mixer and fill it...
Motorhome will probably only drive on and of about 8-10 times a year so hopefully grass will last a few years and if it does I’ll cut in some replacements...
As above
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
I’d dig down 6” and would lay two layers of Council type paving flags, one on top of the other staggered over the joints. Builders merchants sell the council type paving flags but you can also pick them up cheap on Facebook’s marketplace.
With laying one on top of another, you’d be hard pressed to crack them if laid flat and straight.
May work out cheaper than your concrete option, plus you could easily take them up and re-grass if you wanted.
Jun 10, 2010
8,510
20,220
Shrewsbury (sometimes)
N&B Clou Liner MAN
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
Buy four of those plastic jobbies that you use on rally fields when it’s wet.
Two on each side laid lengthways, job done.:D
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
There you go. Fill u'r boots.
If you cant find how to do it in there then it cant be done
Just had a quick read about laying artificial grass in the above site - are you sure u want to do that?
829
1,946
Wildax Europa PVC
Sorry to disagree but this does not look like a good solution to me. The gravel is going to spill over onto the lawn in no time, especially where the mh drives because the tyres will pick it up, and the grass is likely to go ragged over the edges and be difficult to cut. It needs a hard edge around it like paviours, kerbing, brick on edge etc to define and protect the edge IMO.
hth
Jon
He's going to cover it with artificial grass, though, not real grass.
Silver-Fox
9,266
29,091
Cheltenham Spa
Rapido
im a not so newbie
Smiffy can I have a go ?
If it were me I would dig down around 400mm and twice the width of the wheels.
I would fill the trenches with concrete and use rebar.
Then level all the area with coarse compacted sand and lay the Astro turf over the area.
No need to go over the top in the area you’re going to park the van.
This area can be separated from the other grass area.
If you’re doing all the area it can be prepped with around 200mm of type one compacted again layed with coarse sand compacted.
If the ground is really boggy you can fit land drains.
43,329
49,444
There's a private old folks complex near us comprising four two story blocks of flat.
All the resident parking is on plastic grid over soil with pea gravel infill.
It's been there around 40 years and still hasn't sunk.
Jun 10, 2010
8,510
20,220
N&B Clou Liner MAN
hth
Jon
I was referring to the photos you posted.
Just smiffy
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Having investigated more I’m going with the plastic grids which have a load rating of 5t...
I have dug down and compacting some crushed granite, laying the grids and covering with same granite. Then I’m laying down some membrane, sand then covering the whole area with artificial grass..
This area doesn’t get used other then to park the Motorhome on when we’re home and this will be the easiest method for me to do myself and probably the most cost effective and I think will be adequate for the Motorhome....:)
I’ve all ready dug out yesterday and lying the rest today... I’ll take a pick for you when finished :LOL:
Minxy
32,651
66,543
E Yorks
Carthago Compactline
I can't remember if you said earlier, but why the 'need' to cover the drive itself with artificial grass? I can understand you wanting to remove the rest of the grass itself and replace it if you don't want the maintenance but I think going over the granite will look weird and probably lumpy.
Would it be an idea instead to remove the grass and put down weed suppressant membrane and then 'granite' the whole lot so it blends with the new drive bit?
Silver-Fox
9,266
29,091
Cheltenham Spa
Rapido
im a not so newbie
You won't get much growing through artificial grass :)
Minxy
32,651
66,543
E Yorks
I beg to differ, it depends very much on the quality of the grass and it isn't a cheap option either, we've certainly seen 'weeds' in some artificial grass, maybe down to how well, or not, it was laid but I'd much rather have it all looking the same and if the grass on the granite part wears it will look naff.
Silver-Fox
9,266
29,091
Cheltenham Spa
Rapido
im a not so newbie
Probably saw surface weeds.
All the the artificial I've seen are a woven type back and bound together with a type of plastic.
There are holes to allow water to migrate through but a weed would be very lucky to hit one of said holes :)
Aug 22, 2017
829
1,946
Wildax Europa PVC
My turn, my turn ...... please, please sir ... my turn!!!! :D
Easiest, cheapest and quickest solution ....
sell the car! :rofl:
As the Swedes would say: "Tänk utanför boxen!"
Just smiffy
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Ok, dug a couple of trenches put in a few inches of crushed granite then put the plastic grids in and covered with same granite.... they are slightly lower then the lawn as when I put the membrane down and then the artificial grass covering the “whole lot’ of grass you can see in the pictures, the lawn will sink slightly as the grass will die off...
So, more room on my drive and no jungle to cut when we come back from hols..???
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Trouble with Granite gravel is the mould that get on it turns it black ish
It's like a pebble dashed house, looks good to start with then the mould sets in and it looks absolute shite.
Stick with the broken slate you already have would be my advice.
Just smiffy
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Artificial grass is going over it John....??
Just smiffy
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Update.....
Membrane down, some sand then the grass, looks like and went down like carpet..? although it 28m thick...
I think it’s too green but Mrs thinks it’s ok....
Anyone want to buy a mower....?
TerryL
6,184
8,186
North East
Low Profile
Yes, when we had ours done it looked a bit "unnatural" but after a few months it seemed to mellow down a bit and nobody can tell without feeling it now.
