Gearbox Advise needed (3 Viewers)
creativeglenn
34
Manchester
Hi Top
8 years
Hi everyone we need help.
Last year our 2nd gear was fixed,then 4th gear went and was repaired.
Then the gearbox was faulty again so a recon gearbox was fitted.
One year later just before Dover 4th gear went again now second.
The gearbox yet again needs repairing.
Could this possibly be another problem other than the gearbox creating this problem?
Thanks for your time.
43,337
49,538
what were the various faults....crashing gears, jumping out, difficult selection.
seems very strange to have so many box faults over two seperate boxs.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
It would help enormously if you could let us know what base vehicle your motorhome is built on and what year it is. Having said that the catalogue of gearbox issues you have experienced is extremely unusual. Were the repairs all carried out by the same company? If so I'd suggest you try somewhere else as a first step.
D.
C
creativeglenn
34
Manchester
Hi Top
8 years
Sorry everyone, the van is a 1999 coach built Fiat Ducato Auto Roller 1.9 turbo diesel.
Initially it was the syncromesh between second and 4th that went.
On the recon box we have now its the same problem.
Its crunching into 4th and second is near impossible to put it into.
So I am having to go from 1st to 3rd to 5th total nightmare.
The company that repaired the gearbox then fitted the recon box were Tameside Transmissions but the warranty has run out on the recon box.
They have agreed to look at the box if we get it removed but will naturally want paying on anything they do.
Although I must say all work they did the 1st time round was done through Glossop Caravans under our 1st year warranty.
All the repairs were unsatisfactory on the 1st gearbox the warranty company ended up sending a specialist investigator out to decide what action to take as the warranty company had paid for the initial repairs and like us were not happy.
It just seems strange that now the same fault has appeared.
In our minds its either poor quality recon work from the transmissions company or another fault!
We are not pointing our finger at anyone but we just want this problem sorted once and for all as a gearbox should not keep going wrong should it?
Could the clutch need changing?
We are Manchester based.
Thanks.
43,337
49,538
Tameside Transmissions have been in business for the last 15 years so they should know what they're doing.
please don't take this the wrong way but driving style could be a factor.....
can you press the pedal right to the floor ?...it may not be apparent to you, but you may not be pressing it right down every change.
do you change gear too quickly?....a commercial box is a lot more 'industrial' to a car box and changing too fast can overcome the syncro hubs and baulk rings causing damage.
as Dave Newell said...try somewhere else before you start throwing money at tameside again and if its within your ability, remove the box yourself and save a few hours labour charge.
C
creativeglenn
34
Manchester
Hi Top
8 years
Thanks for the reply.
No its not down to my driving style.
I have gone through everything since we had trouble with the gears on this van.
Even really nice slow changes full clutch down everything.
IM afraid Tameside Transmissions have proved themselves to be nothing but incompetent (even the transmissions specialist found their work bad)and no we wont be going back there.
Pikey Pete
1,481
1,143
o
o
I would suggest that you learn the art of double de-clutching, until such time as you can get the gearbox repaired. The art once learned will stand you in good stead and reduce synchro. wear on future boxes.
As has been pointed out previously these boxes are commercial gearboxes, and need to be driven as such.
Pete:Cool:
wireman
147
Chesterfield
Double declutching will ruin a modern box; summat to do with dog clutches and synchro not liking it.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Easy fix! Pop your bonnet, and trace the big rubber pipe that collects water from your scuttle panel (Grill below the windscreen)
Push this rubber pipe back BEHIND the gearbox. If you wish to extend it, or fasten it there, that is up to you!
What happens is, this pipe dumps all the rainwater on top on the gearbox and mount area - your box fills with water and everything breaks up. First sign is the flickering speedo needle, then first will get a little crunchy, then second will get awkward and reverse will need teasing in.
Common problem - dead easy fix!:winky:
wireman
147
Chesterfield
Papajohn: yes but Pete wrote this
and it was that bit I was alluding to...:thumb:
Pikey Pete
1,481
1,143
o
o
In reply I have to say there is no evidence that I am aware of, that states that Double De-Declutching has an adverse effect on a Synchromesh Gearbox.
So if anyone has evidence, I'll change my driving technique, taught me in the Army when I was a mere sprog.
Pete:Cool:
wireman
147
Chesterfield
because in a modern snchro box you will actually be making the synchro work harder than letting it do its work itself and this can lead to premature wear. Just think how a modern synchro works on a constant mesh gearbox when compared to a (stonger) non constant mesh box. If you blip the throtlle and create a further mismatch in speed the synchro has to work much harder.
C
creativeglenn
34
Manchester
Hi Top
8 years
I don't get this post, are you suggesting I actually do this or look at this as being the problem?
How do I double clutch?
What will happen if I just leave this and just drive it as is for now?
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
Double de-clutch is, clutch pedal down, out of gear, clutch pedal up then down again, select next gear, clutch pedal up, twice as much legwork on the clutch pedal. Also, l have never heard of water getting into gearboxes this way, what happens when travelling through rainwater, and we get plenty of that in the UK? Finally, l have not heard of damage being done double de-clutching.
ginge61
429
n/wales
c class/t25 vw
since noah was a lad lol
get something other than a fiat have a look at all the probs with gear boxs mostley fiat based
chris v
28
Burton upon Trent
Water in gearbox
Hi,
Water can and does get into the gearbox as the scuttle drain dumps the water right onto the gearbox and it can get in through the breather. I think it tends to happen when the van is parked up and also some motorhomes dump more roof water onto the windscreen than the original van. No manufacturer will admit there was ever a problem:Angry: but Fiat did fill all the webs on top of the box with silicone? I have had this problem but more to the point when I had a service at a Peugeot agent they filled the gearbox with the latest spec. oil which is thinner than standard gearbox oil and all the problems you have appeared on my van and vanished again when I had "normal" gearbox oil put in. I suggest that you have the gearbox drained and refilled with standard gearbox oil, don't go to a main agent, they charge about ÂŁ60:Eeek:, then see if you have any improvement. Mine was sorted by Nottingham Clutch and Gearbox but they may be to far away from you,
Regards,
Chris.
C
creativeglenn
34
Manchester
Hi Top
8 years
Thanks for the replies.
I will change the gearbox oil to normal gearbox oil and see how I go.
The problem is even when looking at trading to a new motorhome a hell of a lot of them are fiat based vans.
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Thats because there a cheap good looking base vehicle.
You get what you pay for.......would you but a Fiat car?????? (no neither would !!!!!!):ROFLMAO:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Sorry, not looked at this post for a while.
The water ingress causes the gearbox to fail. Try emptying the gearbox oil, refreshing and see what she is like. If the problem persists, then it is rebuild time.
Whichever, do shove the drain pipe well away from the gearbox!:thumb:
2,348
10,199
Well, I have .. so there .. :roflmto:
Seicento Sporting 1997 , paid ÂŁ650 including the A frame..
bought as a toad 18 months ago, but now used as daily transport, rust free, 90k miles on the speedo, , does 45 - 50 mpg and never misses a beat .. cheap as chips to insure and yes, I would buy another.. :thumb:
C
creativeglenn
34
Manchester
Hi Top
8 years
Isn'ta transit?
Iveco?
Don't VW's have problems?
Surely anything no matter how cheap should'nt go twice in less than 4000 miles?
C
creativeglenn
34
Manchester
Hi Top
8 years
Yep we had a fiat punto fantastic car.
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
And at ÂŁ650 for 18 months use its money well spent but if it developed an expensive fault would you get it fixed or scrap it??:winky:
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Isn'ta transit?
Iveco?
Of course they all have problems of 1 sort or another but the simple fact of the matter is that its a light weight van which when converted is probably running at its full capacity which unlike a delivery van (that is driven empty for about 1/2 its life) is only ever going to get heavier with "stuff" that you put in it.
Ive said it for years and will continue to do so till the day they put me in a box...... most Euro motorhomes are put on base vehicles not fit for the job. We need to take a lesson from the USA as far as building motorhomes and put them on a chassis with a suitable engine and running gear that has a lot of spare capacity and is not at 95% of it weight limit before anyone get inside it.:winky:
C
creativeglenn
34
Manchester
Hi Top
8 years
But it wouldn't develop an expensive fault as it cant as everything about fiat car spares including gearboxes are cheap until you get onto the bloody vans!:cry:
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Cant you find a decent secondhand box for it?? Or are they as rare as rocking horse droppings because they fail on a regular basis??
C
creativeglenn
34
Manchester
Hi Top
8 years
I should be able to yes but there's a but.
I am looking at changing the very much under powered 1.9 td engine thats clearly not up to the job to a 2.5 and gearbox at the same time preferably becasue as you mention its working its nuts off especially up hills as it working at full or near full capacity.
There must be a flip side to your theory though Daz as otherwise why would they keep on doing it year in and year out?
What sort of vehicle with similar fuel costs would you suggest out of interest?
As naturally buying a new engine and box makes me think is it time to upgrade rather than modify?
