Gaslow (2 Viewers)
Jan 8, 2022
59
16
Kent
Swift Kontiki 794-23
Hi, Message below posted to Gaslow Company. Has anyone experienced this problem?
Steve
Below
Thanks for help
2 Images attached
As mentioned, we filled both up on Friday and both gauges showed as full
Since Friday we have boiled 3 kettles and used cooker once and now half empty. When we did same in spain last year one bottle lasted five weeks as we were on hook up for heating all the time as we are at moment. This morning it had used 1/4 tank approx. but now shows half empty?
Attached
Regards
Steve
53,938
151,951
Although the gauges are the float type that are supposed to be fairly accurate a lot of people have problems with them. Best way is to weigh them.
Nov 1, 2023
110
2,875
Adria
Be aware folks
I've just discovered that the only local garage for LPG has taken the pump out!
It seems I'm going to have to swap back to Calor.
Sod's law. I've just fitted a Dimes Wave to be able to remotely read the gas level in the first of the 2 x 11kg Gaslow tanks so it looks like I'll have no use for it now :mad::cry:
Nanniemate
6,246
43,805
Wales
IH
Be aware folks
Where are you . I have only recently got refillable and as yet had no issues I top.up when I need it
Asda in Cardiff has 2 lpg pumps
Feb 14, 2021
3,700
7,992
Milton Keynes, UK
Burstner Lyseo 727G
Be aware folks
Not having one locally doesn't bother me. Only filled up in my home town once in 3 years. If I am travelling I will be going a reasonable distance - there will be one somewhere near my route. I just look on the LPG.EU app for the nearest one on my route. I travel a lot in Europe too and most garages have them over there. I run just one Gaslow and have a calor as a back up.
Feb 14, 2021
3,700
7,992
Milton Keynes, UK
Burstner Lyseo 727G
As said Gauges are not accurate. Turn one off and run the other until it no longer works - then you will know how long it lasts.
Basildog
2,216
3,622
I would agree that the clip on gauges on the older type Gaslow / Gasit bottles are not good at all.
But these newer Gaslow / Alugas multivalve gauges are pretty good šŸ‘
Hereā€™s a picture of roughly how to read the gauge.
tonka
10,861
21,594
Cannock, Staffs
A class Burstner 800
Since 2000
Be aware folks
You dont state where you are, so it could just be in your location.
In my area I am lucky to have several within a few miles, I am finding taxi companies are installing their own tanks to supply their drivers converted cars and also sell to the public. (y)
Nov 1, 2023
110
2,875
Adria
North Devon.
Nearest garages now Minehead, Milton Damerel & Exeter area.
Nov 1, 2023
110
2,875
Adria
Why not just fill up on route like most of us do?
I don't drive & am not en route to anywhere as living in my MH until find new home.
My son has been coming once a fortnight to drive to what was nearest garage (about 30 mins away) which now has no pump
bigtwin
5,287
10,031
Derby
Concorde
Ahh, yes refillables arenā€™t great if youā€™re living in your van at a single location and donā€™t drive! Thatā€˜s quite a unique scenario that doesnā€™t apply to the vast, vast majority of users.šŸ‘
Ian
Nanniemate
6,246
43,805
Wales
IH
North Devon.
It's just a matter of picking it up before you run out.
The nearest to my house is about 10miles away but I'd never use it as its not on route to anywhere
I just top.it up either on my way home or on the way out.
I did run.out of calor a few times but now have a back up canister cooker
Try not to worry just it it filled and then keep topping up
I understand gas anxiety but once you get into the route of topping up it so goes.
Edit just seen your not mobile. Maybe consider a very large calor bottle and get it delivered if possible. Your in a unique situation not sure how close you are to a campsite that has gas .they may help you
43,411
50,079
Living in the van full time it's not going to be the cheapest option reverting to calor.
As said, fit a diesel heater for warmth and just use gas for cooking etc.
Diesels going to be available at any garage for a long time to come.
Feb 18, 2017
4,147
8,032
Greenwich, London, UK
Hymer MLT 570
Frankly, it would have been if you were living in a caravan rather than a motorhome.
Motorhomes are designed for short stays in one place.
Caravans are much better for long term stays in one location.
My van is fitted with Gaslow AND Calor.
My local garage has also stopped selling LPG, so I simply fill up en-route to wherever I'm going.
I have the Calor as emergency back up (last swapped the bottle in 2019)
What it means is if I were static like yourself, I could get a couple of the large (47 Kg) domestic bottles delivered (About Ā£80 quid each).
And plug them into the gas system on a 2m hose, but keep the GasLow system as backup.
It's a simple enough conversion to do DIY, but as it involves gas I'd recommend you get a gas certified person to do it.
If you get your son to take your van to VanBitz at Taunton they could sort it out whilst you wait. (Book ahead!!!)
Sep 29, 2019
3,085
7,143
Hymer Exsis
20 years
Get an emergency hose and use a big calor bottle if you arenā€™t moving for a while. šŸ‘
daveclare
1,011
5,418
North West
Florium Wincester
Europe & USA since April '21
Never had a problem with gauges on our 11kg gaslow bottles. Seem to be quite accurate. Never have a problem getting lpg, wherever we go in UK or Europe. Never used or needed calor and probably never will.
Sep 17, 2017
5,577
10,420
Birmingham, UK
A-Class
I got a Gaslow 11kg about 2 years ago, so maybe I have one of the newer gauges? The gauge points at full for about the first 20% or so. But the end of red is roughly where empty is. So I think it's ok.
Jan 11, 2022
610
582
Pilote P732 2011
3rd Time around, since 2000
That would be the best idea, they deliver too so no need to move van other than to give it a run out.
Nov 1, 2023
110
2,875
Adria
MH was bought when my husband (who drove) was alive. I've just kept it on.
Nov 1, 2023
110
2,875
Adria
I'm ashamed to say that I know nothing about diesel heaters - not even where one would/could be fitted.
Is there a good site online which would tell me more?
Nov 1, 2023
110
2,875
Adria
RV Installations in South Molton suggested a mix & match much as you suggest. They're qualified to do gas work, too, so if I end up having to make alterations they'd be nearer but many thanks for the Taunton info.
I'm moving to another site at the weekend. I'll look around to see if anyone else uses the big bottles as they're definitely the more economical option. If not, when I'm more settled in, I'll ask the owners.
32,709
66,779
In Spain you are not likely to be putting the heating on much if at all which I assume you are here so it will gobble your gas.
