rf9ridrer
- Sep 6, 2022
- 78
- 38
- 2007 ACE FIRENZE
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks, we are away for the first time tomorrow and the one bottle is nearly empty so i thought i`d ask before i had no gas!Yours is automatic as it has an auto switch over regulator. (The bit with the green triangles on it)
Currently your chosen cylinder is the left one, and it is still providing your gas. When it runs out the green will go red, and the gas will come from right hand cylinder.Thanks, we are away for the first time tomorrow and the one bottle is nearly empty so i thought i`d ask before i had no gas!
Brilliant, Thanks. Just wish the instructions were clearer.Currently your chosen cylinder is the left one, and it is still providing your gas. When it runs out the green will go red, and the gas will come from right hand cylinder.![]()
Yes that is correct.Just so I'm clear. If the white marker is pointing to the left bottle, and that bottle runs out of gas, the green segments turn red.
What age is the van ?Are the Gaslow systems fully automatic when one bottle runs out?
Nothing to switch on or off ?
I`ve read the instruction leaflet that came with the motorhome, but its not very clear!
I`ve attached a picture of our system, Thanks.
The control only sets which is the primary cylinder. i.e. The primary cylinder will empty first then it will automatically switch to the other cylinder providing both cylinders are turned on.I wondered why it was described as Automatic when I had to turn that white control around!
The van is 15 years old, although i will have to check the date of the Gaslow installationWhat age is the van ?
As others have already said yes you can operate manually or automatic changeover.
Personally I never use automatic changeover valve.
Also always alternate the supply bottle after filling as eventually you can overfill the unused cylinder in certain conditions.
Is that for me?Here’s the automatic changeover valve/ regulator that’s been installed.
Not correct for a leisure vehicle as it’s incorrect pressure and capacity.
Single stage regulator without any over pressure protection device.
Yes it’s not a leisure vehicle regulator,Is that for me?
You saying the regulator is wrong?
So are the regulators in the pic correct?Here’s the automatic changeover valve/ regulator that’s been installed.
NoSo are the regulators in the pic correct?
Ok, thanks, could you point me in the right direction as to what i need?
Yes a suitably qualified professional fitter should know the difference between regulators.Ok, thanks, could you point me in the right direction as to what i need?
Also, should this have been flagged up in a gas report, as it was checked last year before i bought it, and report said ok, with no leaks?
Thanks for the help.
Yes that’s a Cavagna 30 mbar leisure vehicle regulator.Thanks all for the help, i`ll have to see what i can get here in Spain.
We have a Gaslow agent 40km away, is this suitable?
Gaslow 30mbar Auto Changeover with Built-in Regulator 8mm
The Gaslow Automatic Changeover bulkhead 30mbar Regulator for Caravans & Motorhomes, provides the most compact and high specification to gas control and also incorporates the latest safety features.www.gaslowdirect.com
