Mel, I thought it was a new van, it looks filthy.Hi and welcome to the fun house!
Can you tell me what MH you have and ideally an image of it so we can see where's suitable. I fitted a small filler in the side of my Carthago recently, much easier to find a spot for than the larger Gaslow fillers:
View attachment 347248View attachment 347249
Its not 'stressing' the hose that's the issue, but the joint becoming loose due to the movement of the door being opened/closed. I believe one of the companies used to offer a specific fitting for putting it through a door but don't do it now.Wasn't able to fit mine in the skirt so it was fitted by a very reputable fitter in the gas locker door. Perfectly OK so long as there's space to accommodate the hose without stressing it. Also means all the hoses are inside the locker out of harms way.
Cheeky s*d! That was taken a few days later - we'd been out in it and when we got home I remembered to take the photos for you lot! So ...Mel, I thought it was a new van, it looks filthy.
Having fitted our refillable gas system a few times now to different MHs/campers I've found that this is by far the easiest way to fit the filler ... it's taken me longer to compose the below than it would to do it for you!Thats the one..... I like your logic.... I think that definitely a better option than the Gas Door...
You're very welcome. Below is where I put it on our last Globecar PVC, you can see the filler hose on the left (the green snake!) which came out of the bottom of the bumper then up through the gas locker drop vent which was located behind the aluminium protection plate (there was a 8cm or so gap between them so sufficient to get the hose in). The 'green snake' is actually a piece of large bore hose pipe that I cut down lengthways and then cable tied over the filler hose to give it some protection.Ah Wow Mel.... Thats brillant... thank you for that..... I will give it a shot and let you know how much destruction I do...
I have a Benimar and it fits perfectly on the skirt. I did originally fit it in the gas locker, but the wide safety collar round the pump nozzle made it difficult to fit on. I only fitted an 11kg bottle. As its refillable I don't see the point of having a second bottle. I have a bluetooth gas sensor on it which is accurate to a few % so I always know exactly how much gas is left.That makes alot of sence. I was leaning towards putting it into the locker, I have a Mileo 231 Benimar... Will take another look at the body work and see if I can find a nice spot for it... Thanks everyone. Super responses....
That's about where I had my filler originally, but it the plastic safety ring on the filler nozzle made it very difficult to connect up. Hence I put the filler on the skirt underneath.Thanks for all the images... Some very clever adaptions... I especially like yours Nixdorfer....
Maybe you should consider a patent on that one...
