Gas Fire (1 Viewer)
maacracing
52
10
dundee
a class
Hello all, seen to be having a little trouble with gas fire (carver 3000) the pilot light ignites no problem but the main burner doesn't and will not come on.
I have tried to do a little research it seems that Truma have bought out Carver and have discontinued Carver parts.
Checked on ebay etc etc and it turns out that there are 3 different types of burner valves for the same
gas fire.
Just wondering if any one else has had a smiler problem
Mike
43,390
49,818
could just be the thermo-couple, which sits in the pilot flame and when hot opens the main gas valve allowing the main burner to light.
I believe the part number is 602699
also, check the nut on the 'cold' end of the thermo-couple where it enters the gas valve....is it tight.
if not, tighten finger tight plus 1/4 turn.
maacracing
maacracing
52
10
dundee
a class
Hi, Replaced the thermo coupling September last year as the fire kept going out.
maacracing
maacracing
52
10
dundee
a class
Thank you very much for all of that will check it out this morning.
Mike
chatter
3,689
937
cheshire
5th wheel
I concur with fleurette, Gary at arcsystems is the guy to contact, he is the guru of anything Carver , also on his site you can download the info for any carver system
