Gas Bottles whilst Visiting France & Spain....
UK
Hymer MLT 570
Our 1st Motorhome
Sorry in advance as I know there’s been a lot of posts on the Forum about gas bottles in Europe, but a lot of the discussions are what can be done in preparation for a trip, whereas I’m afraid we’re away already. ?
It’s our first trip to France and Spain, and we thought we’d got everything sorted and were advised to have a second leisure battery and second 6kg gas bottle fitted (Calor Propane), but we’ve missed a crucial point that we really should have gone for refillable gas canisters..... and we are kicking ourselves now!
So we’ve just cutover onto the second 6kg Calor Propane bottle. We are staying on a mixture of Aires and Sites, and have got as far as Northern Spain and hoping to continue touring around for another week or two, or longer if possible. The gas will be used, for heating and hot water when necessary, and cooking.
[ETA I originally said that we were using gas for the fridge when travelling, but as per Lenny’s reply, that’s incorrect and it runs on 12V when travelling - thanks Lenny!]
Would it be best to find a Motorhome workshop in Southern Spain when we get there, to update the gas setup to allow us to use a locally bought gas bottle? I think when we get home we’ll be getting the refillable gas system installed, so we just need to get fixed up so we can use locally bought gas whilst we’re over here.
Any suggestions gratefully received - and sorry for being such numpties! ?
You will only need to change the pigtail to be able to use a Spanish bottle, you can often pick up bottles at the flea markets.
You shouldn't be using the gas to run the fridge when traveling it should be running of 12 volts.
We were in exactly your position two years ago (except we don't have a second leisure battery). In Spain it is easy to get a second hand Repsol or Cespa Spanish gas bottle from car boots or several campsites had them for sale. (We paid €10 euros for one). Then buy a Spanish adaptor that will fit your existing pigtail ( from memory about €16 from a gas supply shop, though I can't recall the name of the shop but there are many. Then it's a simple task of taking your Spanish bottle to garage or other gas supplier and swapping it for a full one. Much cheaper than Calor gas in the U.K. Attach the new adaptor and connect to the pigtail. And Bob's your mother's brother!
Upvote 1
Tell everybody on here what you have in way of pigtail from your current Reg.(assuming the Avatar you have is your 'van) to your connection to your propane bottle.
Then we'll be able to get our heads around what you need.
I know you can buy/hire a 6k repsol bottle from their garages.
From the Ferreteria, (Ironmongers, found in every Spanish town) you can buy an 'Adapter' that will sit on top of that bottle. It is just like a Regulator they use in Spain but has no innards to regulate the gas flow.
The only problem I have is working out how to connect your current Reg. fitted to the 'van to the Adaptor. The thread at the side of the Adaptor is a left hand threaded 22mm male that is identical to that found in the UK between the Regulator and a small Butane bottle. Its also the same as used to connect the larger french bottles but I note you are in northern Spain.
It may be that you can obtain a Spanish bottle from a Spanish Rasto (second hand shop) or on the larger sites, they may be be prepared to sell/hire you a larger Spanish bottle but you will still be left with the pigtail problem unless the previously mentioned Ferreteria sells pigtails.
You could also try a Caravan Motorhome dealer in your area.
Sorry I can't be any more help but I'm at the bottom of the Peninsula at the mo.
Good Luck.
Just note that the Spanish bottles are larger than UK bottles and you may find it may not fit your locker if your moving around. OK if you are on one site as you can leave it outside.
Hi Lenny, Thanks very much for your reply and advice - much appreciated! Sorry that was my mistake - the fridge is indeed running on 12V when we’re travelling.
Hi Ingwe! Thanks very much for your reply, that’s reassuring to know that we’re not the first to have this happen! Also thanks for your advice it’s much appreciated and very helpful! ?
Hi Emmit! Thanks very much for taking the time to reply to our post, we really appreciate it!
I’ve just taken a photo of the connector on the gas bottle, and also of the installation in the gas cupboard - I hope this provides the extra info.
Also, the gas control system fitted is a “Truma DuoControl CS” system (and also to confirm the photo in our avatar is our Motorhome - it’s a 2017 Hymer MLT57).
Thanks very much Jimbo - I’ve just posted a photo above of our gas locker, but we’ll certainly take your comments into account when looking to buy a Spanish gas bottle, so thanks very much for alerting us ref the size of the bottles! ?
Thanks for the update.
As I thought, you have a pigtail that is a male left hand thread going into your bottles.
You need to source a bottle in Spain.
That will have an exit point nothing like what you have. It leaves the bottle vertically and is topped with an Adaptor (Adaptador para botella de gas) in Spanish. Here's a photo.
You can see that the exit point on the Adapter is the 'other way around to that of your propane. You need a pigtail that bolts ONTO the Adapter not INTO the bottle.
Your gas bottle housing looks big enough for a large Spanish bottle but still check. Obviously you will at best have to take out a small bottle.. If you have a bbq point in your garage or van side you can also feed in from a Spanish bottle thru that. You just need the regulator that emmit posted and the hose with just an open end you can connect to your bbq point. The regulators ar around 10 euros and available in Chinese shops and most diy hardware type shops.
The hose you have is a UK propane one.
A UK butane hose fits the Spanish adaptor, fortunately these are available from the Spanish motorhome supply shops. Though not cheap.
That post by Emmitt was a picture of a connector not a regulator if using your bbq point you should not use without a regulator so you would also need to purchase one.?
Minor but necessary correction to Jim Jimbohorlicks post.
You don't need a Regulator. You need an Adapter.
Speve
The OP requires a gas bottle from Spain. He requires to somehow connect the gas bottle to his van.
Yes, he could connect via a BBQ (if he has one) BUT (big but) the correct way to do it via an adaptor in his gas locker to his inbuilt Regulator, NOT via a BBQ point, leaving the bottle on the outside of the unit.
Speve's right ( in my humble opinion) There is confusion about adaptors and regulators. The Spanish bottle needs an adaptor not a regulator, that will take a pigtail to the poster's van's bulkhead regulator.
Have a read of Speves post after having previously read my last post and respectfully reread what you've just posted.
You may wish to make a correction
Emmit, I think we're saying the same thing. At least that is my reading of the thread. I agree entirely with your post #10. My real point was to address the idea that the answer to the poster's problem was to connect a regulator to the BBQ point.
If I've caused offence I apologise. None intended.
Evening,
Good grief, offended? Naa.
In the past, I've been offended by experts.:h:. Yours didn't register on the talcum scale.
No worries.
Just how many days has the first bottle lasted and how many more days must the gas last?
The OP might be better getting a second bottle in France on the way back.
I see many supermarkets selling gas there
Mike
I was only pointing out that you had not posted a regulator but a jumbo connector and if connecting said bottle to a bbq point could be disastrous ???
Try this company in Spain for refillable system fitting and filling up your present bottles, I think they are on the south coast of Spain but may have contacts all over Spain so maybe give them a call
Or phone +34 616 96 94 96
Good luck Flatpackchicken
Gasbottle International
Gas Bottle Refills – Propane & Butane
(By appointment)
We supply and refill gas bottles of all nationalities and systems
+34 616 96 94 96
Call Us without compromise!
We operate on Marbella.
Bring your gas bottles to us for converstion, exchange or refill.
Refills preferably in the mornings by appointment.
Marbella pick up point:
36º 30' 14" N 04º 50' 37" W
We can offer our Services in Andalusia (Spain) from Gibraltar to Malaga, including
  • San Roque
  • Manilva
  • Marbella
  • Calahonda
  • Torremolinos
  • Estepona
  • Sabinillas
  • Elviria
  • Fuengirola
  • Costa del Sol
Hi everyone, thanks so much for your replies - we really appreciate all of your advice - thanks! ?
We would prefer to connect the new Spanish bottle to the existing gas system and regulator via a new pigtail and adapter suitable for the new Spanish style bottle.
Please can I just check that we've understood correctly what we need to purchase?
Gas Bottle: buy a new Spanish style gas bottle from Repsol (from a garage as per Emmit's Post #4), or buy a used bottle from a site or flea market.
Pigtail: buy a new pigtail - of the UK butane type from a motorhome supplies shop.
Adapter: buy a new adapter (adapter para botella de gas - thanks Emmit!) from an ironmonger, and connect to the new pigtail, which is connected into the inbuilt gas system and regulator in the gas locker.
I hope this is correct but obviously would be grateful to hear of we've missed anything! ?
Thanks again!
Should you decide to extend your travels and get as far as the Algarve, my mate Nigel ( who is English) owns Algarve Motorhome Services and is a Gasit dealer and fitter.
He will come to you, and is only a few km from the small private site we live at.
.......just another option?
If it helps you my end fitting looks like the attached pic onto a standard Repsol cylinder.
This is a my set up
The next photo shows a regulator (which you don't want) the easy way to tell if you have the correct one. Regulators have the pipe pushed on and sealed with a clip. Just to make it more complicated the new adaptors do not have a Red top, but are always connected with a screwed thread.
Hi, it your passing Javea Costa Blanca I will sell you a large full Cepsa propane bottle €23. ? Bob.
(By appointment)
+34 616 96 94 96
  • San Roque
  • Manilva
  • Marbella
  • Calahonda
  • Torremolinos
  • Estepona
  • Sabinillas
  • Elviria
  • Fuengirola
  • Costa del Sol
Morning Flatpackchicken, sorry for the late reply but thanks very much for your post and the link, that's really helpful. We're further north from Marbella at the moment but planning to head south, so that's good to know we can call in there to get our UK cylinder refilled so we then have the new Spanish bottle and the refilled UK bottle as backup. Thanks again! ?
Mike
Morning Mike, apologies for the late reply to your question. We're not 100% sure how long the second UK 6kg bottle will last it, but we've just had two nights where we've not had hook-up, so that will have eaten into it. So we're pretty sure we'll need to sorry out a new Spanish bottle fitted that we can use and replace as necessary for the remainder of our trip.
