Gadget To Measure Water When Filling Tank With Hose From £14.99 (2 Viewers)
Wombles
10,808
11,132
SW England
A few years now
This may a be a gadget too far :wondering: but has some limited use Amazon product ASIN B006MWDQZQ for anyone trying to part fill their motorhome water tank accurately (being mindful of payload) for travelling. Our current internal tank indicator is not accurate at all! We are going to try the Gardena version from Amazon as 5 year manufacturer warranty but cheaper version here Amazon product ASIN B01DU9XQEEHopefully will work well in conjuction with food grade hose & HEOSwater fitting plugged in at that end not the tap end - have had good feedback from others already doing this (y)
Mr Wombles wants a version that cuts off at a set amount of water but couldn't find one like that yet.
Wombles
Wombles
10,808
11,132
SW England
A few years now
Am I missing something or is it a secret?:rolleyes:
Maybe Amazon links aren't showing? It's the Gardena Water Smart Flow Meter https://www.gardena.com/uk/products/watering/hose-fittings/water-smart-flow-meter/966780901/ £17.99 at Amazon
Alternatively Bradas / White Line Digital Water Meter also here at £14.99 https://www.ebay.co.uk/itm/Water-Fl...424466?hash=item236650c412:g:Vy8AAOSwiylXBBul
Oct 12, 2009
10,661
23,651
A Class N+B Arto 69GL
If the internal tank indicator is not accurate then one does not know the contents before measuring the fill, so one does not know the total water load, even after adding the filled amount.
Unless of course one drained the tank before measuring the fill.
I could recount a situation with the fuel in a Viscount aircraft which landed in a field short of Exeter Airport. Everyone walked away unharmed. I was involved in the legal case.
Anyway being found overweight often one is given the option of shedding it and proceeding. If the reason is too much fresh water then shedding that extra weight is easy.
Geoff
2,326
10,070
All flow instruments have a calibration certificate.
form technical data, this meter has as a an accuracy of: ± 5 %
so if you measure a 100 litres, that would be either 95 or 105 litres into the tank.. a difference of 10kg
Wombles
Wombles
10,808
11,132
SW England
A few years now
From feedback it looks like the Gardena meter has good accuracy but anything is better than our internal gauge that jumps in quarter tank segments!
Did say it might be a gadget too far & not to everyones taste :giggle:
2,326
10,070
I though the information would be useful for others when deciding whether to purchase or not.. the data is from Gardena technical information .. >
Technical data:
Water temperature: 5 - 40 °C
Flow area: 2 - 30 l/min
Ambient temperature: 5 - 60 °C
Operating pressure: 12 bar
Measurement tolerance: ± 5 %
Measuring range: (at least ± 0,5 l)
Flow max. 1800 l/h
nothing to do with it being a gadget too far or personal taste .. just data
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I’m looking forward to seeing your new toy in a couple of weeks - do you charge for viewing?
I intend using it instead of an optic on the scotch bottles .. measuring in gallons will be more apt than gills with you around!:beerchug::rofl:
Mr Chrysalis
2,367
317,750
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
Someone on Facebook with the same idea
Does anyone know where to get the blue but in this picture, hose pipe connector to tank?
Wombles
Wombles
10,808
11,132
SW England
A few years now
It's a HEOSwater Universal - great bit of kit (y) - around £22 delivered.
If you search on the forum lots of good reviews - used to be difficult to find the right one but now the Universal version should have solved that.
53,430
149,990
I have an excellent, reliable and cheap method of calculating when I have sufficient water in my tank.
When my foot gets wet the tank is overflowing and I have 170 litres in it.
Foolproof and simple. (y):D:D
Richard.
And trousers when it comes back out the inlet as well, means I managed to get 180 Lt in my 160 Lt tank.:ROFLMAO:
53,430
149,990
Now what would be really useful would be flow sensors on the inlet & outlet of the tank with a readout giving accurate tank levels in litres and monitoring your daily useage. You could then adjust your consumption depending on when you are next able to fill up.
Nothing worse than filling up from a Borne, putting a 100 Lt in then putting another €2 in the slot to find you can only get 20 Lt of the 100 you paid for.:D
Aug 26, 2008
4,762
24,952
B&NES
since 2007
I'm supposed to travel with the 100 litre fresh tank only half full.
That's 5 trips from the tap with a 10 litre watering can. Simples. And good exercise too.
[My gadget-a-holic side is sorely tempted by the in line meter thingy but I must stop collecting so many gadgets.]
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
get a dip stick?
